prime333 Posted May 31, 2015 Posted May 31, 2015 Hello everyone. I made this simple drawing using the line, circle command than using trim. What I would like to do is extrude faces 1, 2, 3, and 4 using the extrude function, but it wouldn't work. I'm wondering if I anyone can tell me why I couldn't extrude these faces and how would I do that. Thank you. Quote
paulmcz Posted June 1, 2015 Posted June 1, 2015 Define each region you want to extrude with closed polyline using pedit command and try again. BTW, you should be able to extrude the circle around number 4 as is. Quote
Dadgad Posted June 1, 2015 Posted June 1, 2015 You should be able to do this using the PRESSPULL command, from existing geometry, without the need to close the polylines. http://www.cadtutor.net/tutorials/autocad/extrude-and-press-pull/ The description of PRESSPULL starts at about 2:45 seconds into this tutorial. Quote
