I have been trying to write a multiple offset command but when I run my command, after I set the offset distance and select an object, I get the error message: no function definition: CAD. Any idea how I can fix this command? I would appreciate any help you guys could provide.
;* C:MOFFSET is a multiple offset command. It requires the user to show the
;* offset direction, select one object, tell how many times to offset it
;* and give a direction for the offset. It requires the User GET Functions.
(defun C:MOFFSET( / ent spt dist)
(setq #mdist (udist 1 "" "Offset distance " #mdist nil)) ;the distance to offset
(while (not (setq ent (entsel "\nSelect object to offset: ")))) ;get the object
(setq spt (upoint 1 "" "Select side" nil (cad ent)) ;get which side
#mnum (uint 5 "" "How many times " #mnum) ;# times
);setq
(setq dist #mdist) ;set a variable to the distance interval
(repeat #mnum ;program loop
(command "offset" dist ent spt "") ;run the offset command
(setq dist (+ dist #mdist)) ;increment the offset distance
);repeat
(princ) ;clean ending
);defun
(princ) ;clean loading
The User GET functions I am using in this LISP are below and to my knowledge work fine, but I think it is easier to troubleshoot when you can test at the end.
;* UDIST: User interface distance function
;* BIT (0 for none) and KWD key word ("" for none) are same as for INITGET.
;* MSG is the prompt string, to which a default real is added as (nil
;* is for none), and a : is added. BPT is base point (nil for none).
(defun udist (bit kwd msg def bpt / inp )
(if def ;test for a default
(setq msg (strcat "\n" msg ": ") ;string'em with default
bit (* 2 (fix (/ bit 2))) ;a default and no null bit code conflict so
);setq ;this reduces bit by 1 if odd, to allow null
(if (= " " (substr msg (strlen msg) 1)) ;no def, if last char is space
(setq msg (strcat "\n" (substr msg 1 (1- (strlen msg))) ": ")) ;then strip space
(setq msg (strcat "\n" msg ": ")) ;else msg OK
) );if,if
(initget bit kwd)
(setq inp
(if bpt ;check for a base point
(getdist msg bpt) ;and use it in the GET commands
(getdist msg)
) );setq&if
(if inp inp def) ;compare the results, return appropriate value
);defun
;* UPOINT User interface point function
;* BIT (1 for no null, 0 for none) and KWD key word ("" for none) are same as
;* for INITGET. MSG is the prompt string, to which a default point variable is
;* added as (nil is for none), and a : is added. BPT is base point (nil for none).
(defun upoint (bit kwd msg def bpt / inp)
(if def ;check for a default
(setq pts (strcat
(rtos (car def)) "," (rtos (cadr def)) ;formats X,Y 2D pt as string
(if ;formats 3D ,Z if supplied and FLATLAND off
(and (caddr def) (= 0 (getvar "FLATLAND")))
(strcat "," (rtos (caddr def)))
) );if&strcat
msg (strcat "\n" msg ": ") ;string them with default
) ;this reduces bit by 1 if odd, to allow null
) );if,if
(initget bit kwd)
(setq inp
(if bpt ;check for base point
(getpoint msg bpt) ;and use it
(getpoint msg) ;but not if nil
) );setq&if
(if inp inp def) ;evaluate results and return proper value
);defun
;* UINT: User interface integer function
;* MSG is the prompt string, to which a default integer is added as (nil
;* for none), and a : is added.
(defun uint (bit kwd msg def / inp)
) );if,if
(initget bit kwd)
(setq inp (getint msg)) ;use the GETINT function
);defun
You are meant to put your code in code tags(?), I think that is what they are called.
If you look at another post showing lisp you will see what I mean, no doubt a moderator will advise.
You might want to look at this gem by Lee Mac,
http://www.lee-mac.com/dynamicoffset.html
Thanks Lee! :beer:
as no doubt you will learn plenty from his code, and might decide you don't need to write a new one. :)
Thanks for the link to the Lee Mac site. I will play with his as it seems to accomplish my goals. I couldn't figure out how to use the code tags. Is there a how to somewhere for that?
Please refer to the Code Posting Guidlines.
In essence, you should edit your posts and surround your code with 'code' tags:
[highlight][noparse]
[/noparse][/highlight]Your code here[highlight][noparse]
