DD21988 Posted May 28, 2015 Share Posted May 28, 2015 First time poster so I apologize in advance if I make a mistake here. If I need to add more info please let me know as well. I'm trying to learn AutoLISP and I'm stuck on this Lisp Routine that I'm trying to write: ;* C:BSCALE changes the X, Y, and/or Z values of existing blocks without ;* affecting properties or attributes. It uses the DXF and UREAL functions, ;* which must be loaded. (defun C:BSCALE ( / en ed old41 old42 old43 new41 new42 new43) (if (and (setq en (entsel "\nSelect block to rescale: ")) ;get the block (= (dxf 0 (setq ed (entget (car en)))) "INSERT") ;test if an insert );and (entmod ;update entity (setq old41 (dxf 41 ed) ;extract old X old42 (dxf 42 ed) ;old Y old43 (dxf 43 ed) ;old Z new41 (ureal 1 "" "X scale factor " old41) ;prompt for new X new42 (ureal 1 "" "Y scale factor " old42) ;new Y new43 (ureal 1 "" "Z scale factor " old43) ;new Z ;change data in entity list ed (subst (cons 41 new41) (cons 41 old41) ed) ;change X ed (subst (cons 42 new42) (cons 42 old42) ed) ;change Y ed (subst (cons 43 new43) (cons 43 old43) ed) ;change Z ) ;setq returns ed );entmod );if (princ) ;end cleanly );defun (princ) ;* When I run the lisp routine I get the error message: no function definition: SETQMSG. The lisp routines DXF and UREAL work fine on their own, but I can post them up as well if it would help. If you guys could tell me why I'm getting this error message and how I can fix it, I would appreciate it. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 28, 2015 Share Posted May 28, 2015 Just having 1 setq for lots of lines is probably where the problem is move your questions new41 to before the entmod maybe. Just me use VL pick object etc then (vla-put-XScalefactor obj new41) Post ureal defun as well. Quote Link to comment Share on other sites More sharing options...
DD21988 Posted May 28, 2015 Author Share Posted May 28, 2015 Thanks for responding. Sorry I am so late in replying. Was a busy day at work. I was in the process of putting the UREAL defun on here when I saw the error within it. I'm a newb. Anyway, problem solved. Thanks for your help. Quote Link to comment Share on other sites More sharing options...
