I am a pipe drafter using FabMEP15
when I need a fitting we have ITM button Menu where I can use my mouse to select the fitting ITM that I need.
Instead of selecting the Fitting itm icon with my mouse I would love to instead type a command that would select the itm instead
is this possible? I don't care how long the command is, because I would make the command into a macro using my gaming mouse.
Try CUI and click on your Fabmep15 menu you should be able to see all the commands that are in the menu including the macro that runs the command
I did check through the CUI and I cannot find these Itm files to configure anything, I believe the menu I am referring to is called the Service menu
the only location I have been able to find these is if I type the command FOLDERS
then I can locate the itm files
I attached a picture of what im talking about when I refer to
.itm files/buttons/icons/fittings
