Hi! I would like a macro which will add a text attribute from an x-ref file to another block attribute which is up to 1.5m around the x-ref element.
example:
Attribute block: WF-PC-L2.0-095
X-REF attribute: L2.0-0368
I' d like to add L2.0-0368 to WF-PC-L2.0-095. The distance between the 2 attributes is no more than 1.5m perimetrically.
I guess coordinates can be the common reference, but i am not faamiliar with coding..
