jan_ek Posted May 15, 2015 Posted May 15, 2015 Hello Is it possible to set the solid properties in order to get the effect shown on the right side of the picture ? Quote
ReMark Posted May 15, 2015 Posted May 15, 2015 What exactly is it that you are trying to achieve? Is it that one solid is opaque while the other is translucent? Quote
jan_ek Posted May 15, 2015 Author Posted May 15, 2015 Below effect how I would get (on the right) Yes, solid A is transparent, Solid B is not transparent Quote
BIGAL Posted May 16, 2015 Posted May 16, 2015 The obvious answer is to use subtract but then you get 3 parts and I take it you only want 2. Quote
jan_ek Posted May 16, 2015 Author Posted May 16, 2015 I would like to make it so there were only 2 solids. The solid "A" does not show what is inside, but it shows what is behind it. I do not know if this is possible but I hope so Quote
marko_ribar Posted May 16, 2015 Posted May 16, 2015 You are speaking neither of wire frame nor hidden (shaded) visual style... You can't have both at the same time, so theoretically and practically this is impossible... You can only make illusion like in your posted pictures... Quote
