Therriault Posted May 13, 2015 Posted May 13, 2015 I'm trying to write a routine to draw a style of cover that we use regularly, but I'm having trouble getting past the math functions in lisp. I should clarify that I don't have a clue on .lsp programing; so any help must take that into consideration to save both of us a lot of headaches. Here is what I have so far: (defun c:SBC () (defun dtr (deg) (* deg (/ pi 180)) ) (setvar "cmdecho" 0) ; Data Input (prompt "\nENTER ALL DIMENSIONS IN DECIMALS ") (setq mthk (getreal "\nEnter Material Thickness: ")) (setq ikr (getreal "\nEnter Cover I/S Knuckle Radius: ")) (setq csf (getreal "\nEnter Cover Straight Flange: ")) (setq covrad (getreal "\nEnter Cover I/S Radius: ")) (setq covlng (getreal "\Enter Cover I/S Length: ")) (prompt "\nEnter Lip I/S Dimension: : ")) (if (= lip nil) (setq lip 0.4375)) (prompt "\nEnter Hinge I/S Width: : ")) (if (= hw nil) (setq hw 1.0)) (setq hdp (getreal "\nEnter Hinge I/S Depth: ")) ; Calculations ;Inside Bend Radius (setq isbr (/ mthk 2)) ;Included Bend Angle at Lip (setq iba1 (dtr 90)) ;Centerline Bend Radius (setq cbr1 (= mthk)) ;Centerline Arc Length at Lip (setq cal1 ((* cbr1 2 pi iba1) / 360))) ;Centerline Arc Length/2 at Lip (setq hafcal1 (cal1 / 2)) ;Centerline Bend Radius at Flange (setq cbr2 ((mthk / 2) + ikr) ;Included Bend Angle at Flange (setq iba2 (angle 90)) ;Centerline Arc Length at Flange (setq cal2 (cbr2 * 2 * pi * iba2 / 360)) ;Circle Blank Radius (setq cirbr (covrad - ikr + cal2 + csf)) ) Quote
Commandobill Posted May 14, 2015 Posted May 14, 2015 Assuming your math is correct and your intent, then below should work alright: ;Inside Bend Radius (setq isbr (/ mthk 2)) ;Included Bend Angle at Lip (setq iba1 (dtr 90)) ;Centerline Bend Radius (setq cbr1 mthk) ;Centerline Arc Length at Lip (setq cal1 (/ (* cbr1 2 pi iba1) 360))) ;Centerline Arc Length/2 at Lip (setq hafcal1 (/ cal1 2)) ;Centerline Bend Radius at Flange (setq cbr2 (+(/ mthk 2) ikr) ;Included Bend Angle at Flange (setq iba2 (angle 90)) ;Centerline Arc Length at Flange (setq cal2 (/ (* cbr1 2 pi iba2) 360)) ;Circle Blank Radius (setq cirbr (- covrad (+ ikr cal2 csf))) Quote
Therriault Posted May 14, 2015 Author Posted May 14, 2015 Great! I didn't know how to sequence the string. Bill T. Quote
Therriault Posted May 19, 2015 Author Posted May 19, 2015 I've gotten past my last hurdle, now after running the routine I am able to input the data, and the all of the drawings from the routine seem to function but I get the following: Pick Formed End View Location: Unknown command "SBC". Press F1 for help. *Invalid* *Invalid* *Invalid* *Invalid* *Invalid* *Invalid* *Invalid* Unknown command "SBC". Press F1 for help. *Invalid* Unknown command "SBC". Press F1 for help. The routine is attached. Thanks! SBC.lsp Quote
BIGAL Posted May 20, 2015 Posted May 20, 2015 some changes (setq lip (getreal "\nEnter Lip I/S Dimension: <0.4375>")) (setq isbr (/ mthk 2.0)) ; if mthk is a Int value like 3 you may not get 1.5 better to divide with a real ; just me (setq dtr90 (/ pi 2.0)) (setq dtr180 pi) (setq dtr270 (* 1.5 pi)); put this at start use variable in code dtr 0 is 0.0 (setq ev2 (polar ev1 dtr90 lbcp)) (command "CLAYER" "03-OBJECT LINE 3" "") ; me (setvar "clayer" "CLAYER" "03-OBJECT LINE 3") If your going to do this type of thing all the time you could make a DCL that is a universal multiline input you can pass the request detail so it can ask many questions have a look at this ;; Input Dialog box with variable title ;; By Ah June 2012 ;; code (ah:getval title) (defun AH:getval (title width limit / fo) (setq fname "C://acadtemp//getval.dcl") (setq fo (open fname "w")) (write-line "ddgetval : dialog {" fo) (write-line " : row {" fo) (write-line ": edit_box {" fo) (write-line (strcat " key = " (chr 34) "sizze" (chr 34) ";") fo) (write-line (strcat " label = " (chr 34) title (chr 34) ";" ) fo) ; these can be replaced with shorter value etc ;(write-line " edit_width = 18;" fo) ;(write-line " edit_limit = 15;" fo) (write-line width fo) (write-line limit fo) (write-line " is_enabled = true;" fo) (write-line " }" fo) (write-line " }" fo) (write-line "ok_cancel;}" fo) (close fo) (setq dcl_id (load_dialog "c:\\acadtemp\\getval")) (if (not (new_dialog "ddgetval" dcl_id)) (exit)) (action_tile "sizze" "(setq item $value)(done_dialog)") (mode_tile "sizze" 3) (start_dialog) ; returns the value of item ) Quote
Therriault Posted May 20, 2015 Author Posted May 20, 2015 Thanks, I'll try those suggestions. Any idea as to the reason for the error after the script runs, just for my information, as I don't know the cause? Quote
Therriault Posted May 20, 2015 Author Posted May 20, 2015 OK, I found the problem. By changing CMDECHO to 1 and following the process I found that I was missing a step in the PLINE ARC, specifically the DIRECTION step. In the PLINE sequence I added "D" after each "A" and solved the issue. Thanks, Bill T. Quote
