rubio_jose Posted May 13, 2015 Posted May 13, 2015 good morning friends ....... please someone help me and tell me how do I align the texts in the profile you are one .... I point at the beginning and at the end .... thank you very much for your time .... Quote
BlackBox Posted May 13, 2015 Posted May 13, 2015 Hard to tell from your screen shot, as I cannot zoom in for a closer look. Might be part of a Band Style - select the problem label, and Properties Palette should specify which label type it is, and allow you to Create/Edit the assigned Style. Cheers Quote
MillerMG Posted May 21, 2015 Posted May 21, 2015 Same here...hard to tell. I would also look into the Band Style settings. You probably have a x/y offset set differently somewhere. Quote
