KimDemarestDDA Posted May 12, 2015 Share Posted May 12, 2015 Hi all, I am trying to get the dimension of the AFF tag to automatically populate with the movement of the dynamic block. As it stands, I cannot get the "AFF" dynamic dimension through an attribute definition. I tried following Ellen's tutorial (here) but no luck. Help is much appreciated. AFF Block Help.dwg Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 12, 2015 Share Posted May 12, 2015 Might I suggest you take a look at lee Mac's Elevation Marker lisp routine? Find it here. It's foolproof. http://www.lee-mac.com/elevationmarker.html Quote Link to comment Share on other sites More sharing options...
KimDemarestDDA Posted May 12, 2015 Author Share Posted May 12, 2015 Thanks for the program suggestion. I am curious if you have ever tried to customize this to meet office visual standards. I couldn't find any way to modify the tag symbol to look like my office's AFF tags. Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 13, 2015 Share Posted May 13, 2015 (edited) No, I have not tried to customize it. I would have to have another look. Did you use a field in your dynamic block as per the tutorial? Good Morning Kim. I finally had a chance to look at your block and it turns out that you did not use a field. If you had there would be a gray background surrounding the text 0'-0" AFF. Did you solve the problem on your own yet? BTW....The block drawing you attached was done in metric units (millimeters) yet the block references the finished floor elevation in feet and inches. Why? Edited May 14, 2015 by ReMark Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 14, 2015 Share Posted May 14, 2015 Kim: I made a dynamic block for you to experiment with and it is included in the attached drawing (saved in AutoCAD 2010 file format). Move the blocks on the magenta colored layer to different positions then invoke the REGEN command. You should see the elevations change. One block is used for each elevation. By the way, I included a stretch action on the line under the text too. AFF Tag ReMark.dwg Quote Link to comment Share on other sites More sharing options...
