2015 default point creation style
I'm trying to apply my specific styles for my points but it is grayed out and won't let me change it. This is C3D 2015, anybody else run into this problem?
Thanks in advanced!
LL
Edited by lambeau-leap
Using Civil 3D 2014-2016 here without issue... Go to Toolspace, Settings tab, Point node, Commands node, right click CreatePoints Command, select 'Edit Command Settings...' menu item, expand Default Styles node, and customize as you like.
Cheers
[Edit] - Please remove your linked image.
