AntresSon Posted April 22, 2015 Share Posted April 22, 2015 (edited) I found on the forum some Thread about this theme, but I´m ultra beginner in AutoLISP so i need advice from the beginning. I´m trying to add text and delete text from a block, but not all, only concrete part. Can u help me pls? Any help would be appreciated. Thanks Edited April 22, 2015 by AntresSon Quote Link to comment Share on other sites More sharing options...
Tharwat Posted April 22, 2015 Share Posted April 22, 2015 Welcome to CADTutor . I think we can help you if you explain your idea clearly and in details . Quote Link to comment Share on other sites More sharing options...
AntresSon Posted April 22, 2015 Author Share Posted April 22, 2015 This is my problem ... Quote Link to comment Share on other sites More sharing options...
AntresSon Posted April 22, 2015 Author Share Posted April 22, 2015 upnisito.cz/view.php?filename=8471.png Quote Link to comment Share on other sites More sharing options...
Tharwat Posted April 22, 2015 Share Posted April 22, 2015 Upload a sample drawing if you can . Are you talking about attribute definition ? or just a text object ? Quote Link to comment Share on other sites More sharing options...
AntresSon Posted April 22, 2015 Author Share Posted April 22, 2015 Okey ... On the left side, i need to add this text automatically and on the right side text ,, a.s. BYTČA" in a block i need to remove automatically File upload: http://leteckaposta.cz/593426502 Quote Link to comment Share on other sites More sharing options...
AntresSon Posted April 28, 2015 Author Share Posted April 28, 2015 Can somebody help me pls? Quote Link to comment Share on other sites More sharing options...
Tharwat Posted April 28, 2015 Share Posted April 28, 2015 Can somebody help me pls? I am sorry , I am completely forgot about this thread Anyway , here a routine to delete any text in/out side block definition . (defun c:deltxt (/ s) ;; Tharwat 28.4.2015 ;; (if (and (setq s (nentsel "\nPick Text to delete [even in Block] :")) (wcmatch (cdr (assoc 0 (entget (setq s (car s))))) "*TEXT") (vlax-write-enabled-p (setq s (vlax-ename->vla-object s))) (not (vla-delete s)) (vlax-erased-p s) ) (vla-regen (vla-get-ActiveDocument (vlax-get-acad-object)) acAllViewports) ) (princ) )(vl-load-com) But to add text or any entity to a block , we should know the insertion point coordinates that is related to the block definition itself . Quote Link to comment Share on other sites More sharing options...
AntresSon Posted April 28, 2015 Author Share Posted April 28, 2015 (edited) No add text to a block. I need to remove text from a block ,,a.s. BYTČA" , together with add text (red font) on the left side of the sample file which I sent => (http://leteckaposta.cz/593426502). Pls, can u create complete code for my? Thanks Sir! Edited April 28, 2015 by AntresSon Quote Link to comment Share on other sites More sharing options...
Tharwat Posted April 28, 2015 Share Posted April 28, 2015 Okay , Do you have many Attributed blocks in your drawing or just one block ? You want to remove the same text a.s. BYTČA ONLY ? The text in red color would be added in the same location as it is now with the current block to the other attributed blocks ? Quote Link to comment Share on other sites More sharing options...
AntresSon Posted April 28, 2015 Author Share Posted April 28, 2015 ad 1. I have one block only ad 2. Yep, i want to remove a.s. BYTČA only ad 3. Yep, text would be added in the same location as it is now Quote Link to comment Share on other sites More sharing options...
Tharwat Posted April 28, 2015 Share Posted April 28, 2015 I don't know why you want a lisp since the maximum steps you want to do is just two , use the program that I wrote for you in this thread on the text in any block or text string , and copy with base point that text in red and paste in many locations as mush as you want . It does it need a lisp at all in my opinion . Quote Link to comment Share on other sites More sharing options...
BrianTFC Posted April 28, 2015 Share Posted April 28, 2015 AntresSon, if all you are doing is replacing one word or two words with another then just use the FIND command that is already in AutoCAD. Brian, Quote Link to comment Share on other sites More sharing options...
AntresSon Posted April 29, 2015 Author Share Posted April 29, 2015 My problem is, that I have a lot of drawing files (about 6K) and I have to change these files automatic with adding red text together with deleting a text ,,a. s. Bytča" Quote Link to comment Share on other sites More sharing options...
Tharwat Posted April 29, 2015 Share Posted April 29, 2015 My problem is, that I have a lot of drawing files (about 6K) and I have to change these files automatic with adding red text together with deleting a text ,,a. s. Bytča" Select the red text that you want to copy to every drawing then right click and choose ClipBoard -> Copy with base point then pick your base point . Now open every drawing use my previous posted program in this thread to delete the text in the block then use Cntl+V to paste the red text into your desired base point . Very easy Quote Link to comment Share on other sites More sharing options...
AntresSon Posted April 29, 2015 Author Share Posted April 29, 2015 But 6000 drawing files ... It´s a huge volume ... So I though that it is possible, I open drawing file => run AutoLisp code => close drawing file, and that´s all... So okey, anyway, Thanks very much for your time Quote Link to comment Share on other sites More sharing options...
Tharwat Posted April 29, 2015 Share Posted April 29, 2015 Okay , let us get back to it and write a complete program to delete that specific text from that specific Attributed block . NOTE: the red text that you want to add is a block reference in that attached drawing , is it okay with to make it a text object instead of a block ? Quote Link to comment Share on other sites More sharing options...
Tharwat Posted April 29, 2015 Share Posted April 29, 2015 (edited) Anyway , try this program and let me know how you get on with it . (defun c:Test (/ s) ;; Tharwat 29.4.2015 ;; (if (setq s (ssget "_X" '((0 . "INSERT") (2 . "raz-1-a")))) (progn ((lambda (i / sn nx e d) (while (setq sn (ssname s (setq i (1+ i)))) (setq nx (tblobjname "BLOCK" (cdr (assoc 2 (entget sn))))) (while (setq nx (entnext nx)) (setq d (vlax-ename->vla-object nx)) (if (or (and (wcmatch (cdr (assoc 0 (setq e (entget nx)))) "*TEXT" ) (eq (cdr (assoc 1 e)) "a.s.BYTCA") (vlax-write-enabled-p d) ) (and (eq (cdr (assoc 0 (setq e (entget nx)))) "LINE") (equal (distance (cdr (assoc 10 e)) (cdr (assoc 11 e))) 0.71 1e-2 ) (vlax-write-enabled-p d) ) ) (vla-delete d) ) ) ) ) -1 ) (vla-regen (vla-get-ActiveDocument (vlax-get-acad-object)) acAllViewports ) (mapcar '(lambda (s p) (entmake (list '(0 . "TEXT") '(8 . "KOT") (cons 10 p) (cons 11 p) '(40 . 2.0) (cons 1 s) '(50 . 1.5708) '(41 . 1.0) '(51 . 0.0) (cons 7 (if (tblsearch "STYLE" "ROMANS") "ROMANS" (getvar 'TEXTSTYLE) ) ) '(71 . 0) '(72 . 0) '(73 . 0) ) ) ) (list "THIS DRAWING CONTAINS CONFIDENTIAL INFORMATION AND IS INTANGIBLE PROPERTY OF KINEX BEARINGS a.s. COMPANY." "WITHOUT WHOSE PERMISSION IT MAY NOT BE COPIED OR HANDED TO A THIRD PARTY" ) (list '(24.0298 61.0431 0.0) '(27.5298 61.0697 0.0) ) ) ) ) (princ) )(vl-load-com) Edited May 5, 2015 by Tharwat Quote Link to comment Share on other sites More sharing options...
AntresSon Posted May 5, 2015 Author Share Posted May 5, 2015 Sorry, bud I didn´t know, that you replied, bc i didn´t get email notice... THANKS, it works! But, there is still ,,V" in a block after deleting. It´s created using lines... Quote Link to comment Share on other sites More sharing options...
Tharwat Posted May 5, 2015 Share Posted May 5, 2015 I updated the codes in post no# 18 . try it and let me know . Quote Link to comment Share on other sites More sharing options...
