Noor-Cad Posted May 26, 2024 Posted May 26, 2024 On 5/7/2024 at 10:24 PM, ronjonp said: Here's another one I've had around for a while modified to get the transparency too. It's also good to exclude items that already contain the suffix so you don't end up with duplicate suffixes. (defun c:layersuffix (/ a el f l nl s tm) ;; RJP » 2024-05-08 (or (setq f (getenv "RJP_LayerSuffix")) (setq f (strcat "-" (getenv "username")))) (cond ((and (setq f (cond ((/= "" (setq tm (getstring (strcat "\nEnter suffix [<" f ">]: ")))) tm) (f) ) ) (setq s (ssget ":L" (list '(-4 . "<NOT") (cons 8 (strcat "*" f)) '(-4 . "NOT>")))) ) (setenv "RJP_LayerSuffix" f) (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (setq el (entget (tblobjname "layer" (setq l (cdr (assoc 8 (entget e))))) '("AcCmTransparency")) ) (or (tblobjname "layer" (setq nl (strcat l f))) (entmakex (subst (cons 2 nl) (assoc 2 el) el)) ) (entmod (subst (cons 8 nl) (assoc 8 (entget e)) (entget e))) ) ) ) (princ) ) is it possible to add suffix to layers by selecting the text instead of entering? is it possible to select by window and then select the text and then next selection and so on in a loop and all the objects are shifted to new layers? Quote
Steven P Posted May 27, 2024 Posted May 27, 2024 Yes, that is all possible - holiday here today but selecting the text and looping through a selection is possible 1 Quote
pkenewell Posted May 30, 2024 Posted May 30, 2024 On 5/26/2024 at 4:41 PM, Noor-Cad said: is it possible to add suffix to layers by selecting the text instead of entering? is it possible to select by window and then select the text and then next selection and so on in a loop and all the objects are shifted to new layers? Here is an update to my generic version that allows for Text selection. At the prompts, you can enter "?" to go to a Select text prompt. ;; New version by Pkenewell. Uses Visual LISP & ActiveX ;; Updated 5/8/2024 to check for existing layers already with new name. ;; - Also updated for optional Prefix and/or Suffix. ;; - Also added new created layer count. ;; Updated 5/30/2024 to add ability to select text for prefix/suffix. (defun C:CNL ( / acdoc cnt el en la llst lt lw lyrs np nl pr ss su tr) (vl-load-com) (setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object)) lyrs (vla-get-layers acdoc) ) (vla-StartUndoMark AcDoc) (if (and (setq ss (ssget ":L")) (setq pr (getstring T "\nEnter Prefix for new layers from selected objects <\"?\" to Select Text, ENTER for None>: ")) (if (= pr "?") (progn (while (progn (setvar "errno" 0) (setq en (entsel "\nSelect Text Object for Prefix: ")) (cond ((= 7 (getvar "errno"))(princ "\nNo Object Selected. Try Again...\n")) ((vl-consp en) (if (not (wcmatch (cdr (assoc 0 (entget (car en)))) "TEXT,MTEXT")) (princ "\nInvalid Object Selected. ") ) ) ) ) ) (if en (setq pr (cdr (assoc 1 (entget (car en)))))(setq pr "")) ) T ) (setq su (getstring T "\nEnter suffix for new layers from selected objects <\"?\" to Select Text, ENTER for None>: ")) (if (= su "?") (progn (while (progn (setvar "errno" 0) (setq en (entsel "\nSelect Text Object for Suffix: ")) (cond ((= 7 (getvar "errno"))(princ "\nNo Object Selected. Try Again...\n")) ((vl-consp en) (if (not (wcmatch (cdr (assoc 0 (entget (car en)))) "TEXT,MTEXT")) (princ "\nInvalid Object Selected. ") ) ) ) ) ) (if en (setq su (cdr (assoc 1 (entget (car en)))))(setq su "")) ) T ) (not (= pr su "")) ) (progn (setq en nil) (repeat (setq cnt (sslength ss)) (setq el (entget (ssname ss (setq cnt (1- cnt)))) la (cdr (assoc 8 el)) ) (if (not (member la llst))(setq llst (cons la llst))) ) (setq cnt 0) (foreach n llst (if (not (tblsearch "LAYER" (strcat pr n su))) (progn (setq ob (vlax-ename->vla-object (setq el (tblobjname "LAYER" n))) col (vla-get-truecolor ob) lt (vla-get-linetype ob) lw (vla-get-lineweight ob) np (vla-get-plottable ob) nl (vla-add lyrs (strcat pr (vla-get-name ob) su)) tr (getpropertyvalue el "Transparency") ) (vla-put-truecolor nl col) (vla-put-linetype nl lt) (vla-put-lineweight nl lw) (vla-put-plottable nl np) (setpropertyvalue (vlax-vla-object->ename nl) "Transparency" tr) (if (tblsearch "LAYER" (strcat pr n su))(setq cnt (1+ cnt))) ) ) ) (if (> cnt 0)(princ (strcat "\n(" (itoa cnt) ") New Layers Created."))) ) (if (= pr su "")(princ "\nNo Suffix or Prefix Given - No new layers created.")) ) (vla-EndUndoMark AcDoc) (princ) ) 1 Quote
Noor-Cad Posted May 31, 2024 Posted May 31, 2024 On 5/30/2024 at 7:34 PM, pkenewell said: Here is an update to my generic version that allows for Text selection. At the prompts, you can enter "?" to go to a Select text prompt. ;; New version by Pkenewell. Uses Visual LISP & ActiveX ;; Updated 5/8/2024 to check for existing layers already with new name. ;; - Also updated for optional Prefix and/or Suffix. ;; - Also added new created layer count. ;; Updated 5/30/2024 to add ability to select text for prefix/suffix. (defun C:CNL ( / acdoc cnt el en la llst lt lw lyrs np nl pr ss su tr) (vl-load-com) (setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object)) lyrs (vla-get-layers acdoc) ) (vla-StartUndoMark AcDoc) (if (and (setq ss (ssget ":L")) (setq pr (getstring T "\nEnter Prefix for new layers from selected objects <\"?\" to Select Text, ENTER for None>: ")) (if (= pr "?") (progn (while (progn (setvar "errno" 0) (setq en (entsel "\nSelect Text Object for Prefix: ")) (cond ((= 7 (getvar "errno"))(princ "\nNo Object Selected. Try Again...\n")) ((vl-consp en) (if (not (wcmatch (cdr (assoc 0 (entget (car en)))) "TEXT,MTEXT")) (princ "\nInvalid Object Selected. ") ) ) ) ) ) (if en (setq pr (cdr (assoc 1 (entget (car en)))))(setq pr "")) ) T ) (setq su (getstring T "\nEnter suffix for new layers from selected objects <\"?\" to Select Text, ENTER for None>: ")) (if (= su "?") (progn (while (progn (setvar "errno" 0) (setq en (entsel "\nSelect Text Object for Suffix: ")) (cond ((= 7 (getvar "errno"))(princ "\nNo Object Selected. Try Again...\n")) ((vl-consp en) (if (not (wcmatch (cdr (assoc 0 (entget (car en)))) "TEXT,MTEXT")) (princ "\nInvalid Object Selected. ") ) ) ) ) ) (if en (setq su (cdr (assoc 1 (entget (car en)))))(setq su "")) ) T ) (not (= pr su "")) ) (progn (setq en nil) (repeat (setq cnt (sslength ss)) (setq el (entget (ssname ss (setq cnt (1- cnt)))) la (cdr (assoc 8 el)) ) (if (not (member la llst))(setq llst (cons la llst))) ) (setq cnt 0) (foreach n llst (if (not (tblsearch "LAYER" (strcat pr n su))) (progn (setq ob (vlax-ename->vla-object (setq el (tblobjname "LAYER" n))) col (vla-get-truecolor ob) lt (vla-get-linetype ob) lw (vla-get-lineweight ob) np (vla-get-plottable ob) nl (vla-add lyrs (strcat pr (vla-get-name ob) su)) tr (getpropertyvalue el "Transparency") ) (vla-put-truecolor nl col) (vla-put-linetype nl lt) (vla-put-lineweight nl lw) (vla-put-plottable nl np) (setpropertyvalue (vlax-vla-object->ename nl) "Transparency" tr) (if (tblsearch "LAYER" (strcat pr n su))(setq cnt (1+ cnt))) ) ) ) (if (> cnt 0)(princ (strcat "\n(" (itoa cnt) ") New Layers Created."))) ) (if (= pr su "")(princ "\nNo Suffix or Prefix Given - No new layers created.")) ) (vla-EndUndoMark AcDoc) (princ) ) Thanks Mr. Pkenewell, Its creating the layers but not shifting the points or objects. Quote
pkenewell Posted May 31, 2024 Posted May 31, 2024 @Noor-Cad I didn't understand that in your short post and it wasn't in the original request for the program. This can be done, but you'll have to wait until I have some more time. Of course you could try to learn from it and add to the code yourself. That is, after all, what this forum is for. 1 Quote
GNolder Posted June 14, 2024 Posted June 14, 2024 On 5/7/2024 at 3:24 PM, ronjonp said: Here's another one I've had around for a while modified to get the transparency too. It's also good to exclude items that already contain the suffix so you don't end up with duplicate suffixes. (defun c:layersuffix (/ a el f l nl s tm) ;; RJP » 2024-05-08 (or (setq f (getenv "RJP_LayerSuffix")) (setq f (strcat "-" (getenv "username")))) (cond ((and (setq f (cond ((/= "" (setq tm (getstring (strcat "\nEnter suffix [<" f ">]: ")))) tm) (f) ) ) (setq s (ssget ":L" (list '(-4 . "<NOT") (cons 8 (strcat "*" f)) '(-4 . "NOT>")))) ) (setenv "RJP_LayerSuffix" f) (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (setq el (entget (tblobjname "layer" (setq l (cdr (assoc 8 (entget e))))) '("AcCmTransparency")) ) (or (tblobjname "layer" (setq nl (strcat l f))) (entmakex (subst (cons 2 nl) (assoc 2 el) el)) ) (entmod (subst (cons 8 nl) (assoc 8 (entget e)) (entget e))) ) ) ) (princ) ) @ronjonp This code is very useful. How would it be modified to freeze every new layer? Quote
ronjonp Posted June 14, 2024 Posted June 14, 2024 (edited) @GNolder Give this a try: (defun c:layersuffix (/ a el f l nl s tm) ;; RJP » 2024-06-14 (or (setq f (getenv "RJP_LayerSuffix")) (setq f (strcat "-" (getenv "username")))) (cond ((and (setq f (cond ((/= "" (setq tm (getstring (strcat "\nEnter suffix [<" f ">]: ")))) tm) (f) ) ) (setq s (ssget ":L" (list '(-4 . "<NOT") (cons 8 (strcat "*" f)) '(-4 . "NOT>")))) ) (setenv "RJP_LayerSuffix" f) (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (setq el (entget (tblobjname "layer" (setq l (cdr (assoc 8 (entget e))))) '("AcCmTransparency")) ) (or (tblobjname "layer" (setq nl (strcat l f))) (entmakex (subst (cons 2 nl) (assoc 2 el) el)) ) (entmod (subst (cons 8 nl) (assoc 8 (entget e)) (entget e))) ;; Store the new layer names in a list (or (member nl r) (setq r (cons nl r))) ) ;; Cycle through new layers and attempt to freeze them (foreach l r (vl-catch-all-apply 'vla-put-freeze (list (vlax-ename->vla-object (tblobjname "layer" l)) -1)) ) ) ) (princ) ) Edited June 14, 2024 by ronjonp Quote
GNolder Posted June 15, 2024 Posted June 15, 2024 13 hours ago, ronjonp said: @GNolder Give this a try: (defun c:layersuffix (/ a el f l nl s tm) ;; RJP » 2024-06-14 (or (setq f (getenv "RJP_LayerSuffix")) (setq f (strcat "-" (getenv "username")))) (cond ((and (setq f (cond ((/= "" (setq tm (getstring (strcat "\nEnter suffix [<" f ">]: ")))) tm) (f) ) ) (setq s (ssget ":L" (list '(-4 . "<NOT") (cons 8 (strcat "*" f)) '(-4 . "NOT>")))) ) (setenv "RJP_LayerSuffix" f) (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (setq el (entget (tblobjname "layer" (setq l (cdr (assoc 8 (entget e))))) '("AcCmTransparency")) ) (or (tblobjname "layer" (setq nl (strcat l f))) (entmakex (subst (cons 2 nl) (assoc 2 el) el)) ) (entmod (subst (cons 8 nl) (assoc 8 (entget e)) (entget e))) ;; Store the new layer names in a list (or (member nl r) (setq r (cons nl r))) ) ;; Cycle through new layers and attempt to freeze them (foreach l r (vl-catch-all-apply 'vla-put-freeze (list (vlax-ename->vla-object (tblobjname "layer" l)) -1)) ) ) ) (princ) ) @ronjonp This works perfectly! Thank you! Quote
ronjonp Posted June 20, 2024 Posted June 20, 2024 On 6/15/2024 at 6:05 AM, GNolder said: @ronjonp This works perfectly! Thank you! Quote
pondpepo9 Posted October 3, 2024 Posted October 3, 2024 On 5/8/2024 at 2:24 AM, ronjonp said: Here's another one I've had around for a while modified to get the transparency too. It's also good to exclude items that already contain the suffix so you don't end up with duplicate suffixes. (defun c:layersuffix (/ a el f l nl s tm) ;; RJP » 2024-05-08 (or (setq f (getenv "RJP_LayerSuffix")) (setq f (strcat "-" (getenv "username")))) (cond ((and (setq f (cond ((/= "" (setq tm (getstring (strcat "\nEnter suffix [<" f ">]: ")))) tm) (f) ) ) (setq s (ssget ":L" (list '(-4 . "<NOT") (cons 8 (strcat "*" f)) '(-4 . "NOT>")))) ) (setenv "RJP_LayerSuffix" f) (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (setq el (entget (tblobjname "layer" (setq l (cdr (assoc 8 (entget e))))) '("AcCmTransparency")) ) (or (tblobjname "layer" (setq nl (strcat l f))) (entmakex (subst (cons 2 nl) (assoc 2 el) el)) ) (entmod (subst (cons 8 nl) (assoc 8 (entget e)) (entget e))) ) ) ) (princ) ) "I'm seeking assistance in creating a Lisp function that can generate a new layer with a custom name and move a selected object to this layer while preserving all of its original properties, including true color and color book information. I'm currently using AutoCAD LT 2024 and typically work on Layer 0. Could you please help me modify an existing Lisp function to achieve this? I'm particularly impressed with its ability to copy true colors accurately. Thank you for your time and expertise." Quote
