Precision Posted April 15, 2015 Posted April 15, 2015 Hi all, I'm familiar with the pedit command to turn a spline into a polyline, but I'm wondering if there's a way to change all Splines to Polylines automatically to save a hell of a lot of time. I've tried loading "Spline-to-Pline" LISP file, It's pretty shocking for keeping a reasonable tolerance and resolution at the same time as I need a line/arc length of at least .3mm for our CNC laser cutter.. Any thoughts? (See attached ACAD file with Splines I'm converting) Cave AUTOTRACE.dxfFetching info... Quote
RobDraw Posted April 15, 2015 Posted April 15, 2015 In ACAD 2014 there is a multiple option in the pedit command. If you have that option, it should be easy enough to select all the splines and apply the conversion. I did a quick test and it works as expected. Quote
