m_sherif005 Posted April 7, 2015 Posted April 7, 2015 Hi all; There is several ways to remove polyline line vertices which every cad user is familiar with. But i am searching for a routine that remove only polyline vertices which is not on point features in a drawing. Is any experiences? Regards Quote
neophoible Posted April 7, 2015 Posted April 7, 2015 Can you post an example of what you are wanting? You are using Civil3D, right? Quote
Murph_map Posted April 7, 2015 Posted April 7, 2015 Look at the "WEEDFEATURES" command or map clean up features in the map3d tools. Quote
m_sherif005 Posted April 8, 2015 Author Posted April 8, 2015 Thank you Murph, But i have tried all methods which is in softwares ability. Quote
m_sherif005 Posted April 9, 2015 Author Posted April 9, 2015 Vertices.dwg The attached DWG contains a 3D Polyline with 4 vertices which 3 of them are on points and one of theme is not on point. I want remove this type vertices (that not on point) from a drawing which have somany 3D Polylines by this situation. Furthermore this most do by a LISP or VBA routine. Regards Quote
m_sherif005 Posted April 12, 2015 Author Posted April 12, 2015 Can you post an example of what you are wanting? You are using Civil3D, right? Vertices.dwg The attached DWG contains a 3D Polyline with 4 vertices which 3 of them are on points and one of theme is not on point. I want remove this type vertices (that not on point) from a drawing which have somany 3D Polylines by this situation. Furthermore this most do by a LISP or VBA routine. Yes i am using civil 3D 2015 & AutoCAD 2012 Regards Quote
