razara Posted April 7, 2015 Author Posted April 7, 2015 scriptwriter helping ? script line: _.open *file* _.checkstandards ?? add standards file - Select standards file- xxx.dwg - Ok- Check Standart File - Fix - Ok - Next - Close ?? _.save _Y _.close Quote
neophoible Posted April 7, 2015 Posted April 7, 2015 razara, how about uploading a couple of sample drawings here, showing the original and one that's been fixed? Quote
neophoible Posted April 7, 2015 Posted April 7, 2015 razara said: Current Dimstyle names are... ekp-ölçü ISO-25 Standart They need to all be altered to... GRC-MM There's a ton of AutoCAD files & blocks, so I really appreciate the help doing this faster. Thanks! http://we.tl/cc1ZMAbXee These Dimstyles are all in separate DWGs, that is, no two in the same DWG, right? Quote
razara Posted April 7, 2015 Author Posted April 7, 2015 Yes, you are right, all blocks are separated and it has to be like that. Thanks. Quote
razara Posted April 10, 2015 Author Posted April 10, 2015 1000, separate block once all dimstyl and textstyle s the way of change with lisp ? Quote
neophoible Posted April 10, 2015 Posted April 10, 2015 neophoible said: razara, how about uploading a couple of sample drawings here, showing the original and one that's been fixed?Did you do this? And it would be best if you put it here and not make folks have to go chase it somewhere. Quote
