Hi,
Would it be possible to create a LISP routine that can take 300-1000 AutoCAD files and rename dimstyle,textstyle automatically?
: Cry:: Cry:
  • Replies 26
  • razara
    15
  • neophoible
    3
  • BIGAL
    2
  • ttray33y
    2
to be more precise; would you please explain me how can I change 1000 seperated block's dimstyle and textstyle with lisp code? The blockes have to be asunder of each one.
key command is -rename
foreach dim style you can use -> (command "-rename" "D" "OLDNAME" "NEWNAME")
foreach text style you can use -> (command "-rename" "S" "OLDNAME" "NEWNAME")
sample:
(defun c:RENDS()
Edited by ttray33y
Just add the lisp to acaddoc.lsp then you need to make a script to do the rest.
open dwg1 (c:rends) close Y
open dwg2 (c:rends) close Y
open dwg3 (c:rends) close Y
Thank you for your interest , but this is not exactly what I wanted , the lisp code block can select a folder should be opened and must be able to collectively process collectively select blockl'ar I want from this folder.
I can hardly understand what you were saying sir.
Current Dimstyle names are...
ekp-ölçü
ISO-25
Standart
They need to all be altered to...
GRC-MM
There's a ton of AutoCAD files & blocks, so I really appreciate the help doing this faster.
Thanks!
http://we.tl/cc1ZMAbXee
We have answered your question you need to write a script ! There are script generators out there check out http://www.lee-mac.com.
I just know my way around the OS using old fashioned DOS commands to make a text file of dwg names then use Word and make my scripts most times say 4-5 minutes and can have hundreds.
Do more googling and search here this is not a new topic "Modify multiple drawings" etc.
Hi raza,
try to use only, the 'qsave' and 'close' commands...
Henrique
razara: You have already started a thread about this topic. Double posting the same questions here will only lead to confusion and make the course of the conversation difficult to follow.
Can you explain a little more what is 'Add Open Fix Next Close'...
Henrique
These commands "Add open fix next" next" will be written in this line, and how to work this question ?
hmsilva asked for an explanation of what you are trying to do. Please explain....in detail.
Hi Hmsilvia and ReMark , Would it be possible to create a scrit or LISP routine that can take 300-1000 AutoCAD files and change dimstyle,textstyle automatically?
You can see at that link about the problem:http://autode.sk/1DEeRoV
Thanks
Please stop creating new threads and adding on posts to old threads for this one question.
It only makes things confusing for everybody.
I have merged the other thread and moved the other posts here.
It might help is you took all the time you are wasting posting everywhere and clearly explain your problem.
