Hi,
When I selected in acad 2013 and in acad 2014 an object the preview was always
dashed with grips. In acad 2015 it is highlighted with grips. where can I modify that back in dashed.
Thanks in advance.
Gr. Joop!
In OPTIONS, on the SELECTION tab, lower left corner, in the PREVIEW section of the dialog. Highly customizable to suit your personal preferences. :wink:
Hi Dadgad,
The problem is that there is no selection preview effect aerea anymore.
gr. Joop!
I found the solution myself.
There is an command named: SELECTIONEFFECT
You can set it to 1 or 0
Problem solved
gr. Joop!
Hi Dadgad,
gr. Joop!
Have you tried looking in the lower RIGHT corner on that same tab? :wink:
Great, glad you figured it out, well done. :)
Yes, I just mentioned SELECTIONEFFECT in THIS THREAD, the other day.
Apparently they have changed those options in 2015 Dadgad and the Options now are different.
