Hi all,
Stuck with a problem
I have a situation, I made a selection set A
(Setq A (ssget))
and worked with it according to my need. then created 2nd selection set
(setq B (sssget))
Now I want to make selection set A active to get
(setq C (vla-get-activeselectionset ********))
how can i do this
waiting for your reply
Why dont you just change the sequence?
And why not use the repeat/ssname approach, why the need for vla-get-activeselectionset ?
What is the main purpose of the routine?
E.g.
(setq A (ssget))
then do your work with "A"
if that's done, create (setq B (sssget))
after this, you can work with "C"
HTH
Wolfgang
edit: 2 minutes too late, pbE was quicker:lol:
Work on the filter of the ssget function , then you may not need for two selection sets .
Exactly!
Hence my question of
I want to create W block using Vla-Wblock that's why I need active selection set....
Here is an example demonstrating how to 'convert' the selection set returned by ssget to an ActiveX selection set as required by the wblock method:
(defun c:mywb ( / doc idx lst sel ssc vsl )
   (if (setq sel (ssget))
           (repeat (setq idx (sslength sel))
               (setq lst (cons (vlax-ename->vla-object (ssname sel (setq idx (1- idx)))) lst))
           (setq doc (vla-get-activedocument (vlax-get-acad-object))
                 ssc (vla-get-selectionsets doc)
                 vsl (vla-add ssc (uniqueitem ssc "mywb"))
           (vla-additems vsl
               (vlax-make-variant
                   (vlax-safearray-fill
                       (vlax-make-safearray vlax-vbobject (cons 0 (1- (length lst))))
                       lst
           (vla-wblock doc
               (vl-filename-mktemp
                   (vl-filename-base (getvar 'dwgname))
                   (getvar 'dwgprefix)
                   ".dwg"
               vsl
           (vla-delete vsl)
(defun uniqueitem ( col key / int rtn )
   (setq int 0)
   (while
       (not
           (vl-catch-all-error-p
               (vl-catch-all-apply 'vla-item
                   (list col (setq rtn (strcat key (itoa (setq int (1+ int))))))
   rtn
(vl-load-com) (princ)
Alternatively, you can populate the ActiveX Selection Set directly using the select method of a Selection Set object.
Thank you genius:thumbsup:
Understood it and solved my problem appropriately
  • 8 years later...
So I took the code example a step further.  If anyone is willing to proof out any overkill that would be appreciated.
;;C:ASR
;; Description:  Select a group of objects and Wblock them.  Use a file name based on the first objects layer
  (defun C:ASR (
                                      ;; cpy
                                      *error* acapp acdoc acdocs acdocmodelspace ssc vsl
                                      _POPUP
                                      _EDITBOX
                                      _VL-Uniqueitem
                                      _MakeBlock
                                      ssetObj ssblk xent
                                      lst idx
                                      A1
                                      Obj
                                      tmpfilznamz
                                      objsInModelSpace
                                      tempvarClearToProceed
    ;;-------FUNCTION SUPPORT GROUP-----------------------------------------;;
      (defun *error* ( msg )
        (if RegExp (vlax-release-object RegExp))
        (mapcar '_ReleaseObject (list acapp acdoc ssc vsl acdocs acdocmodelspace))
            (princ (strcat "\n** Error: " msg " **")))
    ;;-------STANDART FUNCTION GROUP----------------------------------------;;
      (defun _Popup ( title flags msg / wsh res )
        (vl-catch-all-apply
          (function
            (lambda nil
              (setq wsh (vlax-create-object "WScript.Shell"))
              (setq res (vlax-invoke-method wsh 'popup msg 0 title flags))
        (if wsh (vlax-release-object wsh))
        res
      );end defun
      (defun _EDITBOX ( str / han )
          (IF (= str NIL) (SETQ str ""))
          (and (< 0 (setq han (load_dialog "acad")))
              (new_dialog  "acad_txtedit" han)
              (set_tile    "text_edit"    str)
              (action_tile "text_edit" "(setq str $value)")
              (if (zerop (start_dialog)) (setq str nil))
          (if (< 0 han) (unload_dialog han))
          str
      );end defun
      (defun _VL-Uniqueitem ( col key / int rtn )
          (setq int 0)
          (while
              (not
          rtn
      );end defun
      (defun _ReleaseObject ( obj )
          (and obj (eq 'VLA-OBJECT (type obj)) (not (vlax-object-released-p obj))
              (not
                      (vl-catch-all-apply 'vlax-release-object (list obj))
      );end defun
    ;;-------STANDART GLOBAL VARIABLES--------------------------------------;;
      (vl-load-com)
      (setq acapp 	(vlax-get-acad-object)
            acdoc 	(vla-get-activedocument acapp)
            acdocs 	(vla-get-Documents acapp)
            acdocmodelspace (vla-get-ModelSpace acdoc))
    ;; Move all isolated objects to an external drawing using the wblock method
      (if
        (and
          (setq tempvarClearToProceed 2)
          (setq ssblk (ssget))
          (setq a1 (cdr (assoc 8 (entget (setq xent (ssname ssblk 0)))))) ; layer color name to be base of wblock name
          (if (= nil (findfile (setq tmpfilznamz (strcat (getvar "dwgprefix") (_EDITBOX  a1 ) ".dwg"))))
              (print "MSG: ASR-AEWBLOCKMAKE-NAMEDBY-LAYER || File name Unique")
              (print tmpfilznamz)
              (setq tempvarClearToProceed 1)
            );end progn
              (print "MSG: ASR-AEWBLOCKMAKE-NAMEDBY-LAYER || File name Not Unique - User Correction Required")
              (print tmpfilznamz)
            );end progn
          );end if
          (if (= 1 tempvarClearToProceed)
              (repeat (setq idx (sslength ssblk))
                  (setq lst (cons (vlax-ename->vla-object (ssname ssblk (setq idx (1- idx)))) lst))
              (setq ;acdoc (vla-get-activedocument (vlax-get-acad-object))
                    ssc     (vla-get-selectionsets acdoc)
                    vsl     (vla-add ssc (_VL-Uniqueitem ssc "mywb"))
              (vla-additems vsl
                  (vlax-make-variant
                          lst
              (vla-wblock acdoc tmpfilznamz vsl)
              (if
                (and
                  (= 6 (_Popup "Object Interface:" "Would you like to Delete the Objects Previously Selected?  " (+ 4 48 4096)))
                  (> (vla-get-count vsl) 0)
                );end and
                (vlax-for Obj vsl
                  (VLA-DELETE Obj)
              );end if delete objects from the file
              (vla-delete vsl)
            );end progn
          );end if
        );end progn
      );end if
    ;;-------END FUNCTION SUBROUTINES---------------------------------------;;
      (vla-Regen (vla-get-activedocument (vlax-get-acad-object)) acAllViewports)
      (mapcar '_ReleaseObject (list acapp acdoc ssc vsl acdocs acdocmodelspace ))
