I'm not really sure how to describe this problem, but I'll do my best. I've been having a problem lately where whenever I move the cursor, it sort of freezes along the path that I trace with it.
It also will make my underlays and drawings flash between the current zoom level and whatever the previous zoom level was, which makes it really difficult to find my reference points.
I tried uninstalling and reinstalling the program, but that didn't help. If anyone has any idea what's wrong and/or suggestions on how to fix it, that would be greatly appreciated!
While not exactly what you described, you might check that grid snap is not enabled (SNAPMODE = 0) and maybe also try changing SELECTIONPREVIEW from 3 to 2, or even 0 just to see if it makes any difference.
Also make sure you have the latest Service Packs installed.
low end Graphics cards can also suffer from that, when it's forced to use virtual memory.
Might help to provide your Computer and graphic card specs. Maybe your graphics driver version also.
  • 3 weeks later...
That did the trick. Thanks!
