Hey guys,
I'm trying to get the four corners of a rectangle in modelspace set to variables and I'm having a hard time with it.
I'm able to get the four corners into a list, but I'm having a hard time setting each coordinate to a variable.
The issue I'm having at this point is that the second variable duplicates the coordinate values. The first variable
Here's what I got so far...
(defun c:test (/ ptlist x y)
(setq ptlist (massoc 10 (entget(car(entsel)))))
 (defun c:massoc (key alist / x nlist)
(foreach x alist
(if (eq key (car x))
(setq nlist (cons (cdr x) nlist))
(reverse nlist)
) ;end
(princ ptlist)
 (setq x (car ptlist))
 (setq y (cadr ptlist))
 (princ x)
 (Princ)
 (princ y)
I got part of this code from here
When I draw in a rectangle in modelspace and I use this code, this is what I'm getting.
Command: TEST
Select object: ((18.2488 -11.0958) (23.6419 -11.0958) (23.6419 -5.32136) (18.2488 -5.32136))(18.2488 -11.0958)(23.6419 -11.0958)(23.6419 -11.0958)
So it builds the list and sets the first variable right, but it duplicates the second.
Thanks in advance!
e: I haven't added in error trapping yet, just trying to figure this out first.
Edited by chiimayred
updated code, bit at the end
The variable is not duplicated - the function is evaluating the (princ y) expression to print the value of the variable 'y' to the command-line, and is then returning the value returned by the last evaluated expression, which is the (princ y) expression.
Simply add (princ) to the end of the code to ensure that the last returned value is a null symbol, and hence avoid the duplicate output.
Wow, I feel like such a dunce!
Thanks for your reply, this is my first time really working with lists.
