NOVICECADGUY Posted March 17, 2015 Posted March 17, 2015 Good afternoon, I'm trying to figure out the best way to import ASCII files (.xyz extension) into AutoCAD. The end goal is to take survey data from the field and import it such that I have a color coded contour map in plan view that I can give to a client. Up to now most all of my drafting has been 2D so there is a learning curve. Any and all help would be appreciated. Quote
BIGAL Posted March 17, 2015 Posted March 17, 2015 Simplest answer CIV3D but there are other add ons out there search here for Triangulation. Quote
gazza_au Posted March 18, 2015 Posted March 18, 2015 With Civil 3d or Map 3d there are commands/tools to do it, with vanilla AutoCAD one way is this. http://map3d.wordpress.com/2006/06/25/points-from-a-text-file/ Quote
BIGAL Posted March 18, 2015 Posted March 18, 2015 Sorry Gazza_au but bringing in points does not make a surface, even in LT you can bring lots of points in in one go. The OP wants contours for this you need a TIN a triangular irregular network, now contours do not really exist, that got some attention ! Contours are a interpretation of a TIN and displayed in some form, yes you can convert contours to Autocad objects but they are not contours, In CIV3D a contour is a proxy object and can be changed at will again a interpritive object. Again need a surface modelling software plenty available for Autocad. Quote
BIGAL Posted March 18, 2015 Posted March 18, 2015 Search for YMG3 he has posted some free Civil surface modelling tools and they start from a XYZ file. Quote
NOVICECADGUY Posted March 18, 2015 Author Posted March 18, 2015 After spending some time browsing the internet and talking with other people I can give you a better idea of what I have and what I need. I now have civil3d at my disposal so if there is a quick easy way to import point data in civil3d that would be awesome. The workflow goes like this: -receive data that is in NAD 83 UTM format -reproject data to survey feet (I think global mapper software is capable of reprojection??) -import new (reprojected) data into civil3d -create a contour map in plan view (model space) and keep standard title block in paper space -plot to PDF and call it a day I have very limited exposure to civil3d but am pretty knowledgeable about the AutoCAD interface in respect to 2D drafting. I guess I need to research .tin files and go from there but any help is appreciated. Thanks!! Quote
Murph_map Posted March 18, 2015 Posted March 18, 2015 After spending some time browsing the internet and talking with other people I can give you a better idea of what I have and what I need. I now have civil3d at my disposal so if there is a quick easy way to import point data in civil3d that would be awesome. The workflow goes like this:-receive data that is in NAD 83 UTM format -reproject data to survey feet (I think global mapper software is capable of reprojection??) -import new (reprojected) data into civil3d -create a contour map in plan view (model space) and keep standard title block in paper space -plot to PDF and call it a day I have very limited exposure to civil3d but am pretty knowledgeable about the AutoCAD interface in respect to 2D drafting. I guess I need to research .tin files and go from there but any help is appreciated. Thanks!! All of that can be done in Civil 3D, read the tutorials and help files. Then if you have questions post them in the Civil 3d group. Quote
BIGAL Posted March 19, 2015 Posted March 19, 2015 You are on the money, a couple of comments a buggy thing make sure you have contour styles in the template that you use else you will not see contours. HEY MR AUTODESK why not in default dwt. Making contour styles on the fly is painfull if you have none. You may be able to import direct NAD 83 UTM do a bit of a google. It should take about 10 minutes max. Quote
NOVICECADGUY Posted March 20, 2015 Author Posted March 20, 2015 Thanks for all the help thus far...I managed to import my surface and played with some of the settings. The only thing I haven't figured out how to do that I need done is after I have a surface colored based on depth of sounding, I want to add contour lines that run along the edge of elevation changes and have depth labels on them. I have figured out how to make my surface a contour map with sounding labels and I have figured out how to color my surface (2D Banding). I just can't seem to figure out how to overlay contours and labels onto a colored surface. Quote
SLW210 Posted March 20, 2015 Posted March 20, 2015 Since you are now looking for Civil 3D solutions, I have moved your thread to the Civil 3D & LDD Forum. Quote
BIGAL Posted March 21, 2015 Posted March 21, 2015 I have not seen a dual display style so they way around here would be to do your contours then export the contours to plines, same with your lables, redo the rainbow, and contours should still appear. Quote
