I'm posting this for any future people encountering the same issue.
Hopefully it will save them some frustration!
I'm old and I like the Command Line under the tabs. Personal Pref...
I tried letting it float and adjusting transparency settings for several months
and I'm just an old dog.
I just read every thread I could find about how to get the Command line to stay put.
I tried every variation if LOCKUI with no luck.
Saving Workspaces (and new Workspaces) didn't work for me.
CUI didn't work either.
(Restarting ACAD always reset the location)
Easiest Fix - WSSETTINGS -> Check Automatically Save Workspace Settings
ALT Method/Same Command -
Workspaces Pulldown (Upper Left of center)
Where Drafting and Notation, 3D Modeling, 3D Basics are located
Pick Workspace Settings
I did find this mentioned in one thread but it was a bit obscure.
Don't mean to offend anyone, :cry:
just trying to do something to help others the way many on here help me! :)
I'm glad you posted this!!
My company setup multiple workspaces for the different departments, and I was unable to get my stuff to stay put.
This solved my issue!
  • 6 years later...
Thank you!
I was looking all over to make the command line docked.
It used to stay put, don't know why all of a sudden my civil3d 2020 decided not to put command line docked.
but yes other threads were not very clear of what to do.
WSSETINGS worked!
Although, other autocad that I have installed have the WSSETTINGS as do not save automatically, don't know why my Civil3d is acting differently...
but anyway it worked!
Thank you!!
In the CUI you can Customize Workspaces, expand Palettes and select Command Line then modify the properties below.
Workspace Settings do get messed up sometimes like when a palette disappears. Having them automatically saved prevent you from being able to fix the issue by simply switching workspaces back and forth.
  • Like 2
@tombu Thanks!
I thought WSSETTINGS was working, but it did not work after all...
Thanks for the solution!!
CUI - Workspace - Palette - Command Line - Modify properties looks like the right way to fix the issue!!
  • 7 months later...
YEAH!, someone actually responding with a real fix.
