I wanted to create a new thread since it's a different problem even though it is from a previous thread.
Since I never know how many instances of a font that needs changing (SLDTEXTSTYLE) I wanted to create a counter.
http://www.cadtutor.net/forum/showthread.php?91375http://
Digging around I found a way to create my counter number from this thread:
http://www.cadtutor.net/forum/archive/index.php/t-76290.html
How do I make the CNT a subroutine and call it from C:SWT
(defun c:cnt ()
(setq la (cdr (assoc 2 (tblnext "STYLE" T))))
(setq lal (list la))
  (while (/= (setq la (cdr (assoc 2 (tblnext "STYLE")))) nil)
      (setq lal (append lal (list la))
          (setq LEN (length lal))
(defun c:swt (/ i s)
(Princ "\nFinds all SW Text Styles, replaces with ROMANS Font:")
(if (not (tblsearch "STYLE" "ROMANS"))
    (command "_.STYLE" "ROMANS" "ROMANS")
    (while (> (getvar "CMDACTIVE") 0)
           (command ""))))
(setq i 0)
(repeat 9     ; All my LEN from the subroutine here?
  (setq s (strcat "SLDTEXTSTYLE" (itoa i)))
  (if (tblsearch "STYLE" s)
        (command "_.STYLE" s "ROMANS")
               (command ""))))
  (setq i (1+ i)))
(princ))
And of course if there is a "better way" I'm always open to that too!! :D
Thanks Much!
Fixed my own problem.
Is there a better way to achieve all this given my kindergarten programming skills?
(defun c:swt (/ i s la lal len)
 (Princ
   "\nFinds all SolidWorks Text Styles, replaces with ROMANS Font:"
   (command "")
 (setq i 0)
 (repeat LEN                ; All my LEN from the subroutine here
     (command "")
   (setq i (1+ i))
No need for a counter. Just check the name of your text style.
(defun C:swt ()
(vlax-map-collection
 (vla-get-textstyles
   (vla-get-activedocument
     (vlax-get-acad-object)
 (function
   (lambda ( x / n  )
     (if
       (or
         (=  (setq n(strcase (vla-get-name x))) "ROMANS")
                (wcmatch n "SLDTEXTSTYLE*")
        (if
          (not (= "ROMANS" (vla-get-fontfile x)))
          (vla-put-fontfile x "ROMANS.SHX")
(princ n)
I'm not getting the logic for c:cnt routine ILoveMadoka.
But if you are planning to use a "sub-routine" in just one place on a routine, there's no point in creating one. >
(Defun c:something ()
 	(blah blah)
 (while ; or repeat
 	(subroutine);<-- right here and only here
	 (blah blah blah)
 	(blah blah)
);end while
To justify using a sub-routine, at least use it more than once in a routine, [ there's more reason than just that of course ].
(if   	(blah blah)
(subroutine arg)
 (while ; or repeat
     	(subroutine arg)
	 (blah blah blah)
 	(blah blah)
);end while
And you are wanting to convert the c:cnt to a subroutine for the wrong reason. You dont need the repeat function, just go ahead and run the font style change inside tblnext.
I dont know if that is better for you though :)
EDIT: i see you posted anew before i did :D
Edited by pBe
This is Da Bomb!
Thx
(defun C:swt ()
 (vla-get-textstyles
 (function
   (lambda ( x / n  )
     (if
       (or
        (if
(princ n)
pBe,
My original code ran a set number of instances.
Because I didn't always know how many I would find I needed a counter.
I got a way to count the number of instances
and I had the code to change but I didn't know how to marry the two together.
At the moment I thought "subroutine."
Newbie thinking..
