kapureef Posted March 13, 2015 Posted March 13, 2015 my hatch looks jumbled. I remember a command that cleared it up but to my surprise it escapes me. I know you type in the command click the bottom left corner of the screen then the top right of the screen. Does anyone know this command. It fix's bad hatch problems. thnx:) Quote
Murph_map Posted March 13, 2015 Posted March 13, 2015 Don't know if it's in 2004 version but it maybe HPORIGIN. Quote
MillerMG Posted May 4, 2015 Posted May 4, 2015 Not sure if you ever got this figured out. I'm assuming you did since there are no other posts. I have had this issue with concrete hatches. This is because my UCS is set to world. If I move the UCS close to the hatch, hatch it, it comes out fine, then I move it back to world coordinates. Quote
kapureef Posted May 4, 2015 Author Posted May 4, 2015 Thanks I appreciate you taking the time to assist me. I tried what you said and it worked. I also found that I can type the command "snapbase". This too worked, so now I have two solutions. thanks again... Quote
MillerMG Posted May 4, 2015 Posted May 4, 2015 That's great! I'm glad I could help out. This site has helped me with many of my issues. Members like BlackBox, ReMark, BigAl, Murph_map and others are always more than happy to help and usually have a great answer. There are many others, just can't remember off the top of my head their names. Quote
BIGAL Posted May 5, 2015 Posted May 5, 2015 We use Concrete and gravel hatch all the time and we use MGA co-ords, big numbers, it is a case of when using these to just pick a corner of the hatch area as the origin point. Quote
