lando67 Posted March 13, 2015 Posted March 13, 2015 Hi all, I'm new here and have a question about an xref problem in autocad 2015. I'm trying to xref a drawing to use as a sheet border, and the xref is showing up in paperspace with large bullseye tags at the bottom left and top right corners. Does anyone know what this is and how to get rid of it? Thanks! Quote
Dadgad Posted March 13, 2015 Posted March 13, 2015 Welcome to CADTutor. Those sound like GEO TAGS maybe? Which I don't know anything about, and I have probably got the name wrong, but look for anything about geo referencing in drawings. Are you able to select one of them, and if so, what is it called in Properties? It would be helpful if you posted a screen shot. You can just add it to your first post, by using the EDIT POST option in the lower right hand corner of your earlier post, then select GO ADVANCED, followed by the MANAGE ATTACHMENTS option. Of course you could just COPY & Paste to original coordinates, the sheet in, pending clarification. Quote
lando67 Posted March 14, 2015 Author Posted March 14, 2015 Thanks, I actually figured it out already. It probably was two geotags like you're saying. Whatever they were, I deleted them from the xref drawing and problem solved. Appreciate it! Quote
