Is it possible to make this more compact?
(DEFUN C:TEST ()
(if (/= (tblsearch "STYLE" "ROMANS"))
(COMMAND "-STYLE" "ROMANS" "ROMANS" "" "" "" "N" "N" "N")
(if (= (tblsearch "STYLE" "SLDTEXTSTYLE0"))
(COMMAND "-STYLE" "SLDTEXTSTYLE0" "ROMANS" "" "" "" "N" "N" "N")
(if (= (tblsearch "STYLE" "SLDTEXTSTYLE1"))
(COMMAND "-STYLE" "SLDTEXTSTYLE1" "ROMANS" "" "" "" "N" "N" "N")
(if (= (tblsearch "STYLE" "SLDTEXTSTYLE2"))
(COMMAND "-STYLE" "SLDTEXTSTYLE2" "ROMANS" "" "" "" "N" "N" "N")
(if (= (tblsearch "STYLE" "SLDTEXTSTYLE3"))
(COMMAND "-STYLE" "SLDTEXTSTYLE3" "ROMANS" "" "" "" "N" "N" "N")
(if (= (tblsearch "STYLE" "SLDTEXTSTYLE4"))
(COMMAND "-STYLE" "SLDTEXTSTYLE4" "ROMANS" "" "" "" "N" "N" "N")
(if (= (tblsearch "STYLE" "SLDTEXTSTYLE5"))
(COMMAND "-STYLE" "SLDTEXTSTYLE5" "ROMANS" "" "" "" "N" "N" "N")
(if (= (tblsearch "STYLE" "SLDTEXTSTYLE6"))
(COMMAND "-STYLE" "SLDTEXTSTYLE6" "ROMANS" "" "" "" "N" "N" "N")
(if (= (tblsearch "STYLE" "SLDTEXTSTYLE7"))
(COMMAND "-STYLE" "SLDTEXTSTYLE7" "ROMANS" "" "" "" "N" "N" "N")
(if (= (tblsearch "STYLE" "SLDTEXTSTYLE8"))
(COMMAND "-STYLE" "SLDTEXTSTYLE8" "ROMANS" "" "" "" "N" "N" "N")
(PRINC))
Guidance if so please?
mapcar method
(defun c:test nil
([color="blue"]mapcar[/color] ''((x) (if ([color="red"]not[/color] (tblsearch "STYLE" x))
(COMMAND "-STYLE" x "ROMANS" "" "" "" "N" "N" "N")))
((lambda (i / l)
(vl-list* "ROMANS" (repeat 9 (setq l (cons (strcat "SLDTEXTSTYLE"(itoa(setq i (1- i)))) l)))))
 9))
(princ))
Edited by hanhphuc
hanhphuc beat me to it, poor typist me...
(defun c:test ()
(mapcar
(function
  (lambda (x)
    (if
      (not (tblsearch "style" x))
  '("ROMANS" "SLDTEXTSTYLE0" "SLDTEXTSTYLE1" "SLDTEXTSTYLE2" "SLDTEXTSTYLE2")
long time no see jdiala !
nothing beats you, i learned from you too :)
another..
cond method
EDIT: This method only applies changes if current style matched
(defun [b]c:[u]test2[/u][/b] nil
[color="green"];switch current *style to ROMANS ,which styles are limited by user[/color]
 (eval
     (cons 'cond
    (mapcar ''((x)
	       (list
		[color="red"](equal (cdr(assoc 2 (tblsearch "STYLE" (getvar 'textstyle)))) x)[/color]
		(cons 'command (list "-STYLE" x "ROMANS" "" "" "" "N" "N" "N")))
	       ) ;_ end of lambda
	   		    ((lambda (i / l)
	       (vl-list* "ROMANS"
			 (repeat 9 (setq l (cons (strcat "STY" (itoa (setq i (1- i)))) l)))
			 ) ;_ end of vl-list*
	       ) ;_ end of lambda
	      9
	    ) ;_ end of mapcar
    ) ;_ end of cons
     ) ;_ end of eval
This explains similarity of the above test2 before it's being evaluated
[color="green"];where [b][color="blue"]T[/color][/b]= [color="red"](tblsearch "STYLE" (getvar 'textstyle))[/color]
;assume [color="red"]"STY4"[/color] is current style, ie: only "STY4" is effected [/color]
(COND (nil (COMMAND "-STYLE" "ROMANS" "ROMANS" "" "" "" "N" "N" "N"))
     (nil (COMMAND "-STYLE" "STY0" "ROMANS" "" "" "" "N" "N" "N"))
     (nil (COMMAND "-STYLE" "STY1" "ROMANS" "" "" "" "N" "N" "N"))
     (nil (COMMAND "-STYLE" "STY2" "ROMANS" "" "" "" "N" "N" "N"))
     (nil (COMMAND "-STYLE" "STY3" "ROMANS" "" "" "" "N" "N" "N"))
     ([b][color="blue"]T[/color][/b]   (COMMAND "-STYLE" [color="red"]"STY4"[/color] "ROMANS" "" "" "" "N" "N" "N"))[color="green"]; <-- example curent style= T[/color]
     (nil (COMMAND "-STYLE" "STY5" "ROMANS" "" "" "" "N" "N" "N"))
     (nil (COMMAND "-STYLE" "STY6" "ROMANS" "" "" "" "N" "N" "N"))
     (nil (COMMAND "-STYLE" "STY7" "ROMANS" "" "" "" "N" "N" "N"))
     (nil (COMMAND "-STYLE" "STY8" "ROMANS" "" "" "" "N" "N" "N"))
     ) ;_ end of COND
This test3 is similar, it will change current style to ROMANS,
the difference where test2 only works with certain styles
(defun c:[u][b]test3[/b][/u] nil
 (COMMAND "-STYLE" (getvar 'textstyle) "ROMANS" "" "" "" "N" "N" "N")
in fact both test2 & test3 are superfluous which only work for each single condition,
but i just hope that you could find the differences between cond & mapcar examples
HTH
Edited by hanhphuc
updated code & example
  hanhphuc said:
mapcar method
(defun c:test nil
([color=blue]mapcar[/color] ''((x) (if (= (tblsearch "STYLE" x))
((lambda (i / l)
 9))
(princ))
Thank you for the response and the code.
I know I didn't spell out all my criteria but I was just trying to get the function streamlined at the time.
This works perfectly but is producing an undesired side effect.
It creates the text style "SLDTEXTSTYLE0" thru "SLDTEXTSTYLE8" for the styles that didn't exist.
I never know how many of these "styles" will be in a drawing.
There may be 2 there may be 12 or more.
I just ran it on a test drawing with 4 styles:
"SLDTEXTSTYLE0" thru "SLDTEXTSTYLE3" and when it finished I had "SLDTEXTSTYLE0" thru "SLDTEXTSTYLE8"
This is further expounding on the original code but my design intent to get it to check and see
if a style exists and if so change the font if not, do nothing.
(could be any number of styles but they all are named "SLDTEXTSTYLExxx" Where xxx is a number 0-?)
I can live with the code as it sits. It does work. (Thanks again!)
If it didn't create new styes it would be better - if possible.
Can the results of the tblsearch be number?
I don't know how to add a counter.
If/then? While loop? foreach?
I'm pushing the limits of my very limited knowledge....
Edited by ILoveMadoka
another..
cond method
   (eval
     (cons 'cond
    (mapcar ''((x)
	       (list (eval (cons '[color="red"]not[/color] (list '(tblsearch "STYLE" x) 'x)))
	       ) ;_ end of lambda
	   		    ((lambda (i / l)
	       (vl-list* "ROMANS"
			 (repeat 9 (setq l (cons (strcat "SLDTEXTSTYLE" (itoa (setq i (1- i)))) l)))
	       ) ;_ end of lambda
	      9
	    ) ;_ end of mapcar
    ) ;_ end of cons
     ) ;_ end of eval
I'm ashamed to admit that I don't know how to incorporate this into the other.....
my apology, the logical key should be "not",
too bad i just showed the flow but not the contain working
in mapcar method 2nd line
''((x) (if ([color="red"]not [/color](tblsearch "STYLE" x))
in cond method 3rd line
indeed i'm bad typist
jdiala beats me 8)
I think I would lean towards ;
[b][color=BLACK]([/color][/b]defun c:rstyle [b][color=FUCHSIA]([/color][/b]/ i s[b][color=FUCHSIA])[/color][/b]
[b][color=FUCHSIA]([/color][/b]if [b][color=NAVY]([/color][/b]not [b][color=MAROON]([/color][/b]tblsearch [color=#2f4f4f]"STYLE"[/color] [color=#2f4f4f]"ROMANS"[/color][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
   [b][color=NAVY]([/color][/b]progn
    [b][color=MAROON]([/color][/b]command [color=#2f4f4f]"_.STYLE"[/color] [color=#2f4f4f]"ROMANS"[/color] [color=#2f4f4f]"ROMANS"[/color][b][color=MAROON])[/color][/b]
    [b][color=MAROON]([/color][/b]while [b][color=GREEN]([/color][/b]> [b][color=BLUE]([/color][/b]getvar [color=#2f4f4f]"CMDACTIVE"[/color][b][color=BLUE])[/color][/b] 0[b][color=GREEN])[/color][/b]
           [b][color=GREEN]([/color][/b]command [color=#2f4f4f]""[/color][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
[b][color=FUCHSIA]([/color][/b]setq i 0[b][color=FUCHSIA])[/color][/b]
[b][color=FUCHSIA]([/color][/b]repeat 9
  [b][color=NAVY]([/color][/b]setq s [b][color=MAROON]([/color][/b]strcat [color=#2f4f4f]"SLDTEXTSTYLE"[/color] [b][color=GREEN]([/color][/b]itoa i[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
  [b][color=NAVY]([/color][/b]if [b][color=MAROON]([/color][/b]tblsearch [color=#2f4f4f]"STYLE"[/color] s[b][color=MAROON])[/color][/b]
      [b][color=MAROON]([/color][/b]progn
        [b][color=GREEN]([/color][/b]command [color=#2f4f4f]"_.STYLE"[/color] s [color=#2f4f4f]"ROMANS"[/color][b][color=GREEN])[/color][/b]
        [b][color=GREEN]([/color][/b]while [b][color=BLUE]([/color][/b]> [b][color=RED]([/color][/b]getvar [color=#2f4f4f]"CMDACTIVE"[/color][b][color=RED])[/color][/b] 0[b][color=BLUE])[/color][/b]
               [b][color=BLUE]([/color][/b]command [color=#2f4f4f]""[/color][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
  [b][color=NAVY]([/color][/b]setq i [b][color=MAROON]([/color][/b]1+ i[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
[b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b]
-David
This part is loop usung repeat, you example is 0~8
(repeat [color="red"]9[/color] (setq l (cons (strcat "SLDTEXTSTYLE" (itoa (setq i (1- i)))) l)))
EDIT:
Thanks David :)
ILoveMadoka, please notice mr David make style using repeat loop too
You are helping me. No apology required!
Thanks much!
David,
I will check yours out too.
Thank you Sir!
updated in post#4.
*For reference only
Perhaps my confusion:
  Quote
"Combine multiple TBLSEARCH lines?"
if you don't want to create unwanted *style0~8 as in post#2,
which means you refer to styles which already exist?
update this
(defun c:test ( / var old )
(setq var '(cmdecho textstyle ) old (mapcar 'getvar var))
(setvar 'cmdecho 0)
(mapcar ''((x) (if [color="red"](tblsearch "STYLE" x)[/color]
(COMMAND "-STYLE" x "" "" "" "" "N" "N" "N")))
((lambda (i / l)
 9))
(mapcar 'setvar var old)
(princ))
David,
This works perfectly! Thanks much.
You're welcome. You could add some error trapping to ensure ROMANS styel can be made, but most systems haves ROMANS in a search path
