I have a problem with the interference command, when I want to check all interferences of my model, Inventor sends me an error message. When I check pieces individualy I can see interferences. On a prior model I could check all the interferences without a problem.
What could be happening
Is this a subassembly in an assembly by itself? You need something to check it against I'm postulating.
Hi Markflyer thanks for reply. No, there are not subassemblies, there are parts and patterns only, wierdest thing is that I made the same with the other structure selecting the whole structure and did the job.
