Hi All,
I will use Block Authoring Palette, But this is not Getting in MODEL
i will use 2010 version of CAD.
Please Solve my problem.
Advance Thanx,
SADIQ.
If you have used the Block editor to alter a block, it could be that you need to run the attsync command in Model space before you see any changes in existing blocks.
