SunnyTurtle Posted March 6, 2015 Share Posted March 6, 2015 (edited) Hi i want to replace the _open command this works on my old PC but when i go to install on another it just run the default open is there some variable that stops defun from redefining standard autocad commands ; variables set (setq tilemodevar (getvar "tilemode")) (setq varCPROFILE (getvar "CPROFILE")) ; close windows (COMMAND "EXTERNALREFERENCESCLOSE") (COMMAND "LAYERCLOSE") (COMMAND "PROPERTIESCLOSE") (COMMAND "ADCCLOSE") ; Open drawing from vault (if (= varCPROFILE "Vault_r2014_Acad") (progn (defun c:_open () (command "_vltopen" "" ) ;_ end of command );_ end of defun ) ;_ end of progn ) ; autocad variables unset (setvar "FILEDIA" FILEDIAvar) Edited June 8, 2018 by SunnyTurtle Quote Link to comment Share on other sites More sharing options...
