teknomatika Posted March 4, 2015 Posted March 4, 2015 Hello. I have looked here but not found. Does anyone know a routine that enables the auto numbering text strings by selecting one by one? Quote
Tharwat Posted March 4, 2015 Posted March 4, 2015 Quickie one (defun c:Test (/ s i e) ;;; Tharwat 04.03.2015 ;;; (if (setq i (getint "\n Specify the start number :")) (while (and (princ "\n Pick a text :") (setq s (ssget "_+.:S:E:L" '((0 . "TEXT,MTEXT")))) ) (entupd (cdr (assoc -1 (entmod (subst (cons 1 (strcat (if (< i 10) (strcat "0" (itoa i)) (itoa i) ) "-" (cdr (assoc 1 (setq e (entget (ssname s 0))))) ) ) (assoc 1 e) e ) ) ) ) ) (setq i (1+ i)) ) ) (princ) ) Quote
teknomatika Posted March 5, 2015 Author Posted March 5, 2015 Quickie one (defun c:Test (/ s i e) ;;; Tharwat 04.03.2015 ;;; (if (setq i (getint "\n Specify the start number :")) (while (and (princ "\n Pick a text :") (setq s (ssget "_+.:S:E:L" '((0 . "TEXT,MTEXT")))) ) (entupd (cdr (assoc -1 (entmod (subst (cons 1 (strcat (if (< i 10) (strcat "0" (itoa i)) (itoa i) ) "-" (cdr (assoc 1 (setq e (entget (ssname s 0))))) ) ) (assoc 1 e) e ) ) ) ) ) (setq i (1+ i)) ) ) (princ) ) Tharwat, Excellent. I appreciate the availability and sharing. Thanks! Quote
Lee Mac Posted March 5, 2015 Posted March 5, 2015 Hello. I have looked here but not found. Does anyone know a routine that enables the auto numbering text strings by selecting one by one? You could use the 'Replace' option offered by my Incremental Numbering Suite - simply type 'R' when placing text to enter this mode. Quote
Tharwat Posted March 5, 2015 Posted March 5, 2015 Tharwat,Excellent. I appreciate the availability and sharing. Thanks! You are most welcome . Quote
minhphuong_humg Posted March 7, 2015 Posted March 7, 2015 You could use the 'Replace' option offered by my Incremental Numbering Suite - simply type 'R' when placing text to enter this mode. That greate. Thank Lee Mac! Quote
minhphuong_humg Posted March 7, 2015 Posted March 7, 2015 You're welcome! I see still lacks some features: For example: 1.1 1.2 1.3 ..... (1/1 1/2 1/3 can .......) or 1a.1 1a.2 1a.3 ....... (can 1a / 1a 1/2 ........) If added, the great! Quote
teknomatika Posted March 10, 2015 Author Posted March 10, 2015 You could use the 'Replace' option offered by my Incremental Numbering Suite - simply type 'R' when placing text to enter this mode. Lee, also use this routine (NumInc), which is fantastic. However, in this situation in particular, I wanted to add to the sequence number of the selected text string and not just the substitution. Anyway, thank you for your attention. Quote
