I am trying to create blocks that have a fields, I would like to have it so you can just update the field without actually editing the block. Is this possible?
*update* This block is basic notes that need to be shown on different jobs but might have some job specific data that needs to be updates, my thought would be to create a field (or something similar) that someone could just click and add the information they need without opening the editor. But maybe that is just what they will need to do.
are you talking about adding attributes to a block? Check the ATTDEF command.
If you create the block with the notes as an attribute then find will work The quick xxx jumped over the yyy
FIND xxx replace Fox
FIND yyy replace wall
You can replace one or all in a dwg this way
