Hondatek Posted February 22, 2015 Posted February 22, 2015 Ok does this look right? The 80's line remark? Od confused student? Quote
ConfusedStudent Posted February 22, 2015 Posted February 22, 2015 This is what mine looks like. Quote
Hondatek Posted February 22, 2015 Author Posted February 22, 2015 I'm like you now confused now. Quote
ConfusedStudent Posted February 22, 2015 Posted February 22, 2015 I don't know if mine is right. You got a better grade on the last project.... Quote
ConfusedStudent Posted February 22, 2015 Posted February 22, 2015 Maybe it's time for ReMark to the rescue. Quote
Hondatek Posted February 22, 2015 Author Posted February 22, 2015 Lol remark help!!!!! Let me go read this section again. Lol Quote
Hondatek Posted February 22, 2015 Author Posted February 22, 2015 • Choose one of the two methods for interpolating the locations of the contour lines between the spot elevations (or develop a method of your own). Create layer Interpolate (color red, linetype continuous) on which to place each point of intersection. Label each point with the contour interval. For the interval labels, use style INTERPOLATE-TEXT. For this style, use the ROMANS font, a height of 5, and a width of 0.8. • Once you’ve located all the contour intersections on the grid lines, drawing the contours is essentially a matter of connecting the dots. First, set a running OSNAP to NODE. Use Layer Contours (color yellow, linetype hidden), and draw a continuous polyline between any adjacent points that have the same contour interval. Start at one of the edges of the surveyed area and work your way across the entire drawing. Quote
Hondatek Posted February 22, 2015 Author Posted February 22, 2015 As you’re connecting the node points, note how the sides of each grid square, formed by a spot elevation at each corner, will contain two and only two intersections that belong to the same contour interval. (This is true in all instances, except where a contour intersection happens to be in the same location as a spot elevation that serves as one of the grid square’s corners.) If you find a square that has only a single node for a contour interval, check to make sure you didn’t miss marking down another intersection point. • Use the PEDIT command to establish the properties of each contour line. 1. Select each polyline, choose the Ltype option, and then choose the On option. Doing so makes the hidden linetype properties visible even if the line segment isn’t very long. 2. For all contour lines except those marking the 70-foot, 80-foot, and 90-foot intervals, also choose the Fit option for each polyline. Doing so will allow the polyline to curve between node points. • Once you’ve drawn the existing contour lines, you can draw the existing roadways. The main roadway is Cedar Park Drive. Quote
ConfusedStudent Posted February 22, 2015 Posted February 22, 2015 Look at the thread "need help for penn foster civil drafting project" started by Harpal. it may help you. Quote
ReMark Posted February 22, 2015 Posted February 22, 2015 Contour lines generally do not have sharp points. Quote
ConfusedStudent Posted February 22, 2015 Posted February 22, 2015 Oh good I might have gotten it right this time. Quote
Hondatek Posted February 23, 2015 Author Posted February 23, 2015 Confused what line did you use? I used the polyline just as instructions read. Quote
Hondatek Posted February 23, 2015 Author Posted February 23, 2015 this one Remark. ill do this when i get home. by running the PEDIT command and selecting a polyline then the FIT option the polyline will be fitted with a curve that passes through each point. Quote
ReMark Posted February 23, 2015 Posted February 23, 2015 That's the trouble with asking and answering questions that span two threads. A question could be asked in one thread but mistakenly answered in the other. Makes following the course of the conversation problematic. Quote
Hondatek Posted February 23, 2015 Author Posted February 23, 2015 sorry remark. will work on just one thread one question at a time. Quote
