Hi,
I'm using the Vehicle Tracking wizard to produce a roundabout geometric design (which generates the roundabout crowns to the Stockdale method). I have followed the numerous tutorials for this which include the generation of the corridor and then surface for the roundabout.
The roundabout geometry is created from the previously designed horizontal alignments and vertical profiles.
The issue I am continually experiencing in exaggerated undulation in the surface & subsequent crown profiles as they are draped over the generated surface. I have no idea why or how these are being generated this way. I have searched online and emailed various Autodesk webcast presenters asking for guidance to no avail.
If anyone on here could offer any guidance it would be greatly appreciated. I have attached a PDF showing the results of my corridor & surface which illustrate the effect i am describing.
Thanks
in advance
Gman1979
Windows 7 pr 64-bit
AutoCAD Civil 3D 2015
Vehicle Tracking 2015
8GB Ram
Intel Core i7
Roundabout Surface Errors.pdfFetching info...
I have had the same issue using the Intersection Wizard.
Never could figure out what caused it so I ended up just changing the Tin by hand.
Mainly by deleting the points it was inserting at higher elevations and creating new tin lines.
I know that's not much help - sorry:)
Thanks for your reply, if nothing else, at least it’s some consolation that I’m not the only one experiencing this issue :)
I've not had any luck using the roundabout tool in Civil 3D either. Instead I have created the geometry/design all manually.
