  On 9/8/2018 at 4:29 PM, drdownload18 said:
I'm still getting same error :(
Expand
Re: My last and taking into account Tharwat's post that line should be :
(entmake '((0 . "POLYLINE") (70 . 8)))
  • 4 years later...
  On 2/15/2015 at 12:35 PM, Lee Mac said:
Welcome to CADTutor Alex :)
Below is a rough draft of a possible program, but the code should hopefully perform as required:
(defun c:poly23dpoly ( / enx idx lst pll ptl sel )
   (princ "\nSelect points & 2d polylines: ")
   (if (setq sel (ssget '((0 . "LWPOLYLINE,POINT"))))
           (repeat (setq idx (sslength sel))
               (setq enx (entget (ssname sel (setq idx (1- idx)))))
               (if (= "POINT" (cdr (assoc 0 enx)))
                   (setq ptl (cons (cdr (assoc 10 enx)) ptl))
                   (setq pll (cons (mapcar 'cdr (vl-remove-if-not '(lambda ( x ) (= 10 (car x))) enx)) pll))
           (foreach grp pll
               (foreach vtx grp
                   (if (setq vtx (car (vl-member-if '(lambda ( a ) (equal vtx (list (car a) (cadr a)) 1e-4)) ptl)))
                       (setq lst (cons vtx lst))
               (if (cdr lst)
                       (entmake '((0 . "POLYLINE") (70 . ))
                       (foreach vtx lst
                           (entmake
                               (list
                                  '(00 . "VERTEX")
                                  '(70 . 32)
                                   (cons 10 vtx)
                       (entmake '((0 . "SEQEND")))
               (setq lst nil)
Expand
Dear Lee Mac,
i have been using this lisp , and now when i load it get e message,
; error: extra right paren on input
what could be the reason please,
you need to add another ) on the end.
(defun c:poly23dpoly (/ enx idx lst pll ptl sel)
          (setq pll (cons (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= 10 (car x))) enx)) pll))
        )          ;end repeat
      )            ;end progn
      (foreach grp pll
        (foreach vtx grp
          (if (setq vtx (car (vl-member-if '(lambda (a) (equal vtx (list (car a) (cadr a)) 1e-4)) ptl)))
        )          ;end foreach
        (if (cdr lst)
            (entmake '((0 . "POLYLINE") (70 .))
              (foreach vtx lst
                (entmake (list
                           '(00 . "VERTEX")
                           '(70 . 32)
                           (cons 10 vtx)
              )    ;end foreach
          )        ;end progn
          (setq lst nil)
        )          ;end if
      )            ;end foreach
    )              ;end progn
  )                ;end if
)                  ;end defun
  On 9/28/2022 at 9:33 AM, CADWORKER said:
Dear Lee Mac,
Expand
The 'upgrade' to the forum software a few years ago caused every occurrence of "8)" within code blocks to be removed rendering many thousands of code posts unusable; I've now updated my earlier post to reinstate the missing characters.
  • Like 2
  • Agree 1
  • 2 weeks later...
Hello, I've tried the lisp, but it creates a 3dpolyline between the given points.
for example 4 points makes a 3 segment 3dpoly....
how can i get the interpolated height at every vertex?
