Onetafs Posted February 13, 2015 Posted February 13, 2015 Hi! I've been having a problem for quite awhile now with this model, its a chair with a 4mm plywood sheet wrapped around the base of the chair. The plywood sheet act as a backrest for the chair. I seem to lack knowledge of the operation to make it happen. Quote
JD Mather Posted February 13, 2015 Posted February 13, 2015 Attach the *.ipt file here. Your sketch does not appear to be on a plane tangent to the cone. Not sure of the purpose of WorkPlane1? Taper could be included in the Extrusion1 rather than add FaceDraft. Quote
Onetafs Posted February 16, 2015 Author Posted February 16, 2015 Chair.ipt The workplane was unnecessary, and "taper" worked fine aswell, thanks. Well, here's the file! Quote
