Hi. I am searching for a lisp to draw vertical lines like the example of the photo.
1) select point A then select point B
2) Give the length of the first vertical line (example 6.10m)
3) Give the length of the second vertical line (example 12.00m)
4) Pick the side you want to draw this lines
For my drawings i use this units
format-> units -> Decimal,Grads ,Clockwise ,meters, and Direction -> North
Can any one help
Thanks
if A to B is 100.00, how it looks like with the (input same example 6.10 & 12.00)
Do you want a lisp because you cannot draw this yourself?
It seems to be a particular requirement rather than a general routine for everybody.
Sometimes, drawing can mean a bit of effort, and unless you can write your own lisp, why should anyone else do so? Unless they are looking to fill up some time.
hi hanhphuc tha ab length is 8.24m in this example . The length 6.10 and 12 is only an examlpe .I want to have the option to give any length for this vertival line.
Any ideas
Thanks
normal we do something like this
@dist
Command: LINE
Specify first point:
Specify next point or [undo]: @6.1<0
Command:
LINE Specify first point:
Specify next point or [undo]: @12<90
EDIT: In your pic, the lines are diagonal.
or the green line must be perpendicular?
hanhphuc I was thinkng a lisp using Pythagorean theorem to calculate the Intersections point of this vertical lines.
2) Give the length of the first vertical line (from point B example 6.10m)
3) Pick the side you want to draw this lines
Edited by prodromosm
a/sina= b/sinb you only have 1 unknown so can solve the missing angle then go 12 units to the correct pt.
  • 2 weeks later...
I think that Pythagorean theorem is better way because we don't know the angles a,b
If the perpendicular line is fixed by manual input, then the line from A must be diagonal?
Command: test
Pick point A:
Pick point B:
Input perpendicular length:
Pick side to draw..
This example can draw perpendicular line, but not diagonal
(defun c:test (/ os asin _line p1 p2 d2 l1 ad d ok p ang d3 dir ip )
; hanhphuc 25.02.2015
 (setq os    (getvar 'osmode)
asin  '((x) (atan (/ x (sqrt (+ 1.0 (* x (- x)))))))
_line '((a lst) (foreach x lst (entmake (list '(0 . "LINE") (cons 10 a) (cons 11 x)))))
) ;_ end of setq
 (setvar 'osmode 1)
 (if (and (setq p1 (getpoint "\nPick point A: "))
   (setq p2 (getpoint p1 "\nPick point B: "))
   (setq d2 (getdist p2 "\nInput perpendicular length: "))
   (setq l1  (list p1 p2)
	 ad  (mapcar ''((x) (apply x l1)) '(angle distance))
	 d   (cadr ad)
         ok (< d2 d))
   (setq p (getpoint "\nPick side to draw.. "))
   ) ;_ end of and
   (progn (setq ang (asin (/ d2 d))
	 d3  (* d (cos ang))
	 dir (car ad)
	 ip  (apply 'if
		    (vl-list*
			      (minusp (- (* (- (cadr p) (cadr p1)) (cos dir)) (* (- (car p) (car p1)) (sin dir))))
			      (mapcar ''((f) (polar p1 ((eval f) dir ang) d3)) '(- +))
			      ) ;_ end of vl-list*
		    ) ;_ end of apply
	 ) ;_ end of setq
   (_line ip l1)
   ) ;_ end of progn
(if (not ok)  (alert "Perpendicular line exceeds length of A to B!") )
   ) ;_ end of if
 (setvar 'osmode os)
 ) ;_ end of defun
another (not related to code): by theory if diagonal length by manual input, we can't get perpendicular length (line from B) matched with manual input value due to A to B is fixed length
Edited by hanhphuc
osmode 1
Thank you hanhphuc :beer:
huh? :o
great! you are welcome :beer:
