Flora Wong Posted February 12, 2015 Posted February 12, 2015 I am creating a Block with attribute "X" in which X is a field calling the attribute in my section mark block. Is there any mean to show where X is referencing? I know there is a routine Showfieldlink.lsp which draws to the parent object. But the routine does not work with attribute. Quote
Tharwat Posted February 12, 2015 Posted February 12, 2015 Welcome to CADTutor . Have a look at the following THREAD that should help you with what you are after and my program should work if your Operating System is 32 . Good luck . Quote
Lee Mac Posted February 12, 2015 Posted February 12, 2015 Tharwat said: Have a look at the following THREAD Thank you for the recommendation Tharwat Quote
Tharwat Posted February 12, 2015 Posted February 12, 2015 Lee Mac said: Thank you for the recommendation Tharwat My pleasure Undoubtedly yours is really fantastic . Quote
Flora Wong Posted February 13, 2015 Author Posted February 13, 2015 It works!!! Thanks a lot!! I have been search this for a couple of time. Thanks very much for your help !! Quote
Tharwat Posted February 13, 2015 Posted February 13, 2015 Flora Wong said: It works!!! Thanks a lot!! I have been search this for a couple of time. Thanks very much for your help !! All credits go to Lee for the nice work and you 'll learn a lot from that program if you are interested in learning AutoLISP for sure . Quote
Flora Wong Posted February 13, 2015 Author Posted February 13, 2015 Thanks for all of you for the reply and help~ I am learning LISP in my comapnay =] I am trying the object field lsp. I have a field in multileader but I could not locate its parent object ...> Quote
Manila Wolf Posted February 17, 2015 Posted February 17, 2015 Hi Lee. If you are reading this of course, I wonder if is possible to combine two of your own very good codes. The codes are fieldobject.lsp and fieldobjects.lsp I like the idea of having the singular field object highlighted as in the fieldobject lisp as well as the full range of the field boxed as in the fieldobjects lisp. I know that within the fieldobject lisp this line highlights the source of the field: - (redraw en 3) I tried inserting a line similar to this in the fieldobjects code but I couldn't get it to work. I am not even sure if this is a feasible solution. Not a big deal as I can use the codes one after the other, but I did wonder if it was as simple as inserting one line of code. fieldobject.lspFetching info... FieldObjects.lspFetching info... Quote
Lee Mac Posted February 17, 2015 Posted February 17, 2015 Hi Manila, Try changing lines 139-140 from: (lambda ( a ) (vla-getboundingbox (vlax-ename->vla-object a) 'b 'c) to: (lambda ( a ) (redraw a 3) (vla-getboundingbox (vlax-ename->vla-object a) 'b 'c) Lee Quote
Manila Wolf Posted February 18, 2015 Posted February 18, 2015 Hi Lee, The amendment works perfectly for my particular needs. You made my day. As always, sincere thanks for helping me. Cheers. Quote
Lee Mac Posted February 18, 2015 Posted February 18, 2015 You're most welcome Manila Wolf - happy to help. Lee Quote
