How to show parent object of the field ?
I am creating a Block with attribute "X" in which X is a field calling the attribute in my section mark block. Is there any mean to show where X is referencing?
I know there is a routine Showfieldlink.lsp which draws to the parent object. But the routine does not work with attribute.
Welcome to CADTutor .
Have a look at the following THREAD that should help you with what you are after and my program should work if your Operating System is 32 .
Good luck .
Thank you for the recommendation Tharwat :thumbsup:
My pleasure :)
Undoubtedly yours is really fantastic .
It works!!!
Thanks a lot!!
I have been search this for a couple of time. Thanks very much for your help !!
It works!!!
Thanks a lot!!
All credits go to Lee for the nice work and you 'll learn a lot from that program if you are interested in learning AutoLISP for sure .
Thanks for all of you for the reply and help~
I am learning LISP in my comapnay =]
I am trying the object field lsp.
I have a field in multileader but I could not locate its parent object ...>
Hi Lee. If you are reading this of course, I wonder if is possible to combine two of your own very good codes. The codes are fieldobject.lsp and fieldobjects.lsp
I like the idea of having the singular field object highlighted as in the fieldobject lisp as well as the full range of the field boxed as in the fieldobjects lisp.
I know that within the fieldobject lisp this line highlights the source of the field: -
(redraw en 3)
I tried inserting a line similar to this in the fieldobjects code but I couldn't get it to work.
I am not even sure if this is a feasible solution.
Not a big deal as I can use the codes one after the other, but I did wonder if it was as simple as inserting one line of code.
fieldobject.lsp
FieldObjects.lsp
Hi Manila,
Try changing lines 139-140 from:
                    (lambda ( a )
                       (vla-getboundingbox (vlax-ename->vla-object a) 'b 'c)
to:
                    (lambda ( a )
                       (redraw a 3)
Lee
Hi Lee,
The amendment works perfectly for my particular needs. You made my day. :D
As always, sincere thanks for helping me.
Cheers. :beer:
