Jeremykc1977 Posted February 12, 2015 Posted February 12, 2015 When I use plot to pdf, I look at the pdf and everything looks fine, however when I plot said pdf file I get text that is "in jail" the only thing that is different between the different text file is using wipeout or mask, will show the bars. I've tried to upload a pic, but its not letting me. Quote
Spaj Posted February 12, 2015 Posted February 12, 2015 Hi Which .PDF software are you using? The built-in autodesk driver? Quote
Spaj Posted February 13, 2015 Posted February 13, 2015 When I use plot to pdf, I look at the pdf and everything looks fine, however when I plot said pdf file I get text that is "in jail" the only thing that is different between the different text file is using wipeout or mask, will show the bars. I've tried to upload a pic, but its not letting me. As suggested rather use the built in Autodesk DWG to PDF plot driver . Don't think you can upload until you become a full member... Quote
SLW210 Posted February 13, 2015 Posted February 13, 2015 Don't think you can upload until you become a full member... That is incorrect. New members can do anything a Full Member can except PM, External links are moderated and need approval, all else works the same. I've tried to upload a pic, but its not letting me. Try Go Advanced at the lower right of reply box, then Manage Attachments. What browser are you using? As suggested, try the DWGtoPdf.pc3 that comes with AutoCAD to plot to PDF. Quote
