kaan27 Posted February 10, 2015 Posted February 10, 2015 Hi everyone, I have a problem with a following lisp. I want to place parts on strip, but just don't a single row. Because if it is single row utilization ratio is very low, scrap ratio is very high as seen second image. I want to add up and down the parts when increase the width as seen in the image. If I give a value more than the thickness of the strip 2, it gives error. How can fix that. I need your help on this matter. Thanks in advance for your help. strip layout.LSP Quote
ReMark Posted February 11, 2015 Posted February 11, 2015 This type of problem (reducing waste) seems better suited to being solved using a nesting program rather than writing a custom lisp routine. Quote
