I have AutoCad 2015 for Mac, and I can't find the Design Center that I used when I was using AutoCad 2012 for Windows in high school. I have blocks, but only like 7 different ones and none of them are the right dimensions at all.
AutoCAD for Mac does not have the Design Center feature however it does have the Content Palette.
I don't understand your statement about having several blocks but none are the right dimensions. What is the source of the blocks? Were they drawn at a scale of 1:1? Are you using an imperial template or a metric template? Are the blocks imperial or metric?
Good to know. Thanks.
Autodesk says "Content Palette.....is roughly the functional equivalent of DesignCenter."
