Help me, copy a frame by lisp!
Try using a layout with big picture then little layouts use zoom C to pick point inside little layout and set scale etc.
I would go with BIGAL's suggestion, but if you want to work in Model space, try this old routine.
(defun C:CUT (/ *error* e p1 p2 p3 ss echo osmode)
 (setq echo (getvar "cmdecho"))
 (setq osmode (getvar "OSMODE"))
 (defun *error* (msg)
   (if msg (princ msg))
   (command "_UNDO" "E")
   (setvar "OSMODE" osmode)
   (setvar "cmdecho" echo)
 (setvar "OSMODE" 0)
 (setvar "cmdecho" 0)
 (if (and
       (setq p1 (getpoint "\nFirst corner: "))
       (setq p2 (getcorner p1 "\nSecond corner: "))
       (progn (if (not etrim) (load "extrim.lsp" "Extrim not found")) T)
       etrim
     (command "_RECTANGLE" p1 p2)
     (command "_UNDO" "BE")
     (setq e (entlast))
     (setq p3 (polar p1 (angle p2 p1) (* 0.5 (distance p1 p2))))
     (etrim e p3)
;;;      (entdel e )
     (setq ss (ssget "W" p1 p2))
     (command "_copybase" p2 ss "")
     (command "_UNDO" "B")
     (command "_pasteclip" pause)
 (setvar "OSMODE" 0)
 (if (and
       etrim
     (setq e (entlast))
     (etrim e p3)
;;;      (entdel e )
Dear, Stefan BMR!
I like your way because it is my habit (working on the model)! However, if I start on 2 corner points of the rectangular frame is available autolisp work does not seem exactly like the frame to cut autolisp draw. So you can edit autolisp by selecting frame (rectangle)? Please, help me! If so, great. Thanks and best regards!
P / S:
Because, when i load your lisp is Snap (Osnap) Clear all instead select my routine (Endpoint, Midpoint, Nearest)
Thank Stefan BMR very much!
minhphuong_humg said:
Dear, Stefan BMR!
P / S:
Try this one. You can't select an object, but Osnap setting is available.
(defun C:CUT (/ *error* e p1 p2 p3 ss echo undo)
 (if
    (and
       (not (equal p1 p2 1e-5))
       etrim
     (setq undo (getvar 'undoctl))
     (if (= 0 (logand 1 undo)) (command "_UNDO" "_ALL"))
     (command "_RECTANGLE" "_non" p1 "_non" p2)
     (command "_UNDO" "_M")
     (setq e (entlast))
     (etrim e (getvar 'vsmin))
     (command "_zoom" "_o" e "")
     (command "_UNDO" "_B")
     (if (= 0 (logand 1 undo)) (command "_UNDO" "_C" "_NONE"))
 (*error* nil)
Edited by Stefan BMR
 (if
    (and
       etrim
     (setq e (entlast))
 (*error* nil)
Dear Stefan BMR!
It seems that you have not checked out my drawings sent. I downloaded your lisp and try again on my drawings are not working lisp (selected corners of the rectangular frame).
Please try directly on my drawing (attached).
File attach:
http://www.mediafire.com/download/v7qn32qcaq2ighf/Help_Copy_Frame.dwg
Sincerely BMR.
File video demo your lisp:
Thank you very much!
Add the red line
[color=red](command "_zoom" "_o" e "")[/color]
  • 2 weeks later...
Add the red line
  • 2 weeks later...
Dear Stefan BMR!
File attach:
Sincerely BMR.
Dear Stefan BMR!
After a time using your lisp. I found that the only option was lisp squares that look the other shapes (polygons) .You please revise your lisp help me so that I can select different shapes?
I am very grateful to you!
Sincerely thank Stefan BMR!
File attachment image.
[shape color magenta]
