No need Lee. I just search on how to use some commands and change the program you provided. Thanks!
(defun c:asd ( / des dim enx idx sel txt )
(setq code (getint "\n Input Number of glass marking ") )
(repeat code
(setq code_txt (strcat "\n Code left to click: " (itoa code) " "))
(princ "\n")
(princ code_txt)
(setq code (- code 1))
(if (and (setq sel (ssget '((0 . "TEXT,MTEXT,*DIMENSION"))))
(setq qty (getint "\n Input Quantity ") )
(setq qty (itoa qty))
(setq des (open (strcat (getvar 'DWGPREFIX) (vl-filename-base (getvar 'DWGNAME)) ".csv") "a"))
;(strcat (getvar 'DWGPREFIX) (vl-filename-base (getvar 'DWGNAME)) ".csv")
;use this to get filename of cad file
(repeat (setq idx (sslength sel))
(setq enx (entget (ssname sel (setq idx (1- idx)))))
(if (wcmatch (cdr (assoc 0 enx)) "*DIMENSION")
(setq dim (cons (rtos (cdr (assoc 42 enx)) 2 0) dim))
(setq txt (cons (cdr (assoc 1 enx)) txt))
(while (or dim txt)
(write-line
(strcat
(cond ((car txt)) ("")) ","
(cond ((cadr txt)) ("")) ","
(cond ((car dim)) ("")) ","
(cond ((cadr dim)) ("")) ","
(cond (qty) (""))
) ;strcat
des
(setq txt (cddr txt)
dim (cddr dim)
);repeat
(if (= 'file (type des)) (close des))
);defun
