Dear all,
Do you have a lisp to labelling horizontal line or vertical line coordinate, just the line's Northing or Easting coordinate parallel to line ,it can be above ,under or on line, can chose location. and can labelling several lines one time.
thanks a lot.
  xinmh said:
thanks SLW210
Tips:
command: _dimordinate
also can prefix "N=" or "E=" , but it only shows positive value
Updated v1.1: works with LWPOLYLINE & POLYLINE
10.02.2015
http://www.cadtutor.net/forum/showthread.php?90807-labelling-horizontal-line-or-vertical-line-coordinate-parallel-to-line&p=621946#post621946
;; Make Angle Readable      ;credit to ymg
(defun MakeReadable (a)
 (setq a (rem (+ a pi pi) (+ pi pi)))
 (rem (if (< (* pi 0.5) a (* pi 1.5))
 (+ a pi)
 a
 ) ;_ end of if
      (+ pi pi)
      ) ;_ end of rem
 ) ;_ end of defun
[color="red"];v1.1: works with LWPOLYLINE & POLYLINE[/color]
(defun c:test (/ _text ss 2p e lst split glc l)
;hanhphuc 09.02.2015
;label Vertical & Horizontal Grid (WCS)
 (defun _text (tx lst / txsize rot pt)
   (setq txsize (getvar 'textsize)
  rot	 (MakeReadable (apply 'angle lst))
  pt	 (polar	(apply 'mapcar (cons ''((a b) (* 0.5 (+ a b))) lst))
		(+ rot (/ pi 2.))
		(* txsize 3.0)
		) ;_ end of polar
  ) ;_  end of setq
   (entmake (list '(0 . "TEXT")
	   '(72 . 1) ; justify
	   (cons 1 tx)
	   (cons 10 pt)
	   (cons 11 pt) ; justify
	   (cons 40 txsize)
	   (cons 50 rot)
	   ) ; list
     ) ;_ end of entmake
   ) ;_ end of defun
(defun split (lst len / l ls)
 (while lst
   (repeat len (setq l (cons (car lst) l) lst (cdr lst)))
   (setq ls (cons (reverse l ) ls) l nil)
 (vl-remove-if ''((x)(vl-some 'not x)) (reverse ls))
(defun glc (e / obj l cor) ; get *lines coordinates
;hanhphuc 2014
 (setq obj (vlax-ename->vla-object e))
 (foreach p '("Coordinates" "EndPoint" "StartPoint")
   (if	(vlax-property-available-p obj p)
     (setq l (cons p l))
     ) ;_ end of if
   ) ;_ end of foreach
 (setq cor (mapcar ''((p) (vlax-get obj p)) l))
 (eval	(cons 'cond
      (reverse (vl-list* '(t cor)
			 (mapcar ''((a b)
				    (list
				     (list '= (cdr (assoc 0 (entget e))) a)
				     (cons 'quote (list (split (car cor) b)))
				 '("LWPOLYLINE" "POLYLINE" )
				 '(2 3)
				 ) ;_ end of mapcar
			 ) ;_ end of vl-list*
	       ) ;_ end of reverse
      ) ;_ end of cons
) ;_ end of eval
 ) ;_ end of defun
(prompt "\nSelect grid lines.. ")
 (setq ss (ssget ":L" '((0 . "*LINE"))))
 (repeat (sslength ss)
   (setq lst (glc (setq e (ssname ss 0))))
   (foreach 2p	(mapcar ''((a b) (list a b)) lst (cdr lst))
     (eval
(cons 'cond
      (mapcar '(lambda (a b)
		 (list
		       (equal (car (setq l (mapcar a 2p))) (cadr l) 1.0e-
		       (cons '_text (list (strcat b (rtos (car l) 2 3)) '2p))
		       ) ;_ end of list
		 ) ;_ end of lambda
	      '(car cadr)
	      '("E= " "N= ") ; or '("X= " "Y= ")
	      ) ;_ end of mapcar
      ) ;_ end of cons
) ;_ end of eval
     ) ;_ end of foreach
   (ssdel e ss)
   ) ;_ end of repeat
 ) ;_ end of defun
HTH
Edited by hanhphuc
now user can label on polyline as requested
thanks a lot!!!!
@hanhphuc ,I have test the lisp,it work very nice for "line",but it can not labelling the "ployline""3dpoly",could you please add the function to it, thanks a bunch....
  xinmh said:
thanks a lot!!!!
you are welcome xinmh
updated post#4
updated post#4
perfect!!
thanks a lot!!!
you are so warmheart!!!
  • 4 years later...
  On 2/9/2015 at 10:18 AM, hanhphuc said:
Tips:
10.02.2015
 (+ a pi)
 a
 ) ;_ end of if
      (+ pi pi)
      ) ;_ end of rem
 ) ;_ end of defun
		(+ rot (/ pi 2.))
		(* txsize 3.0)
		) ;_ end of polar
  ) ;_  end of setq
	   '(72 . 1) ; justify
	   (cons 1 tx)
	   (cons 10 pt)
	   (cons 40 txsize)
	   (cons 50 rot)
	   ) ; list
     ) ;_ end of entmake
   ) ;_ end of defun
 (while lst
;hanhphuc 2014
     (setq l (cons p l))
     ) ;_ end of if
   ) ;_ end of foreach
 (eval	(cons 'cond
			 (mapcar ''((a b)
				    (list
				 '(2 3)
				 ) ;_ end of mapcar
	       ) ;_ end of reverse
      ) ;_ end of cons
) ;_ end of eval
 ) ;_ end of defun
     (eval
(cons 'cond
		 (list
		       ) ;_ end of list
		 ) ;_ end of lambda
	      '(car cadr)
	      ) ;_ end of mapcar
      ) ;_ end of cons
) ;_ end of eval
     ) ;_ end of foreach
   (ssdel e ss)
   ) ;_ end of repeat
 ) ;_ end of defun
hi Hanhphuc; just used your code and its giving me a message  error: malformed list on input. Could you please help me
HTH
Expand
  On 10/2/2019 at 1:51 PM, CADWORKER said:
Find this line
it is missing the final integer and the closing brace
The brace is easy but the final integer (8) is a guess as this was an error that occured when the system software was upgraded. See reason for edit
(equal (car (setq l (mapcar a 2p))) (cadr l) 1.0e-8)
Edited by dlanorh
Reminded by LeeMac of system upgrade problem
  • 2 weeks later...
  On 10/2/2019 at 8:43 PM, dlanorh said:
Find this line
Expand
Thanks dlanorh,
it was mentioned which 8 ) became smiley was automatic removed in the code tags by the system.
p/s quite long time inactive 😅
Edited by hanhphuc
