Jef! Posted February 4, 2015 Posted February 4, 2015 Hi everyone! Sorry for the lenght, better too many than not enough. This puzzle dazzle me me totally. I'm sure you will like it too. Some coworkers use drawingviews (viewbase). We had some issues for the pages detailing the steel plates to be cutted cnc. Since drawingviews cannot be wblocked, the way to go is to use file-> Export layout to model. It works great, and if lets say all the drawingviews are 1:4, the exported 2d layout scale them accordingly and the result is 1:1.. wblock each part, bam! its done. The problem is that when more than one scale is used, the whole page is exported and scale using the scale of any random view, and CAD rescale the rest with the wrong scale factor. few additionnal precisions concerning drawing views: -they are filtered off of some commands (copy and wblock for instance) -they cannot be fed to an entsel (filtered out leaving error: bad argument type: lentityp nil) ok. my thought, using lisp to give me a message if more than 1 scale is used over the page just so i am aware. After that I have few ideas on what i could do next, but i have to retrieve some information on these drawingviews first. So i'm there, I got my drawing open, my coffee and music. After trying to know about then using entsel, I make another try at the command line Command: (setq zzz (ssget "x" '((0 . "drawingview")))) Excellent beginning. I iterate through the selection and using vlax-dump-objects/dumpallproperties I see them! Victory! I add the defun, a little princ at the end, the closing bracket. (defun C:test ( / ) (if (setq zzz (ssget "x" '((0 . "drawingview")))) (repeat (setq i (sslength zzz)) (setq e (ssname zzz (setq i (1- i))) VLobj (vlax-ename->vla-object e) ) (princ "item #")(princ i)(princ ": Result of dumpallproperties: \n") (dumpallproperties e) (princ "\n\nitem #")(princ i)(princ ": Result of vlax-dump-object: \n")(vlax-dump-object vlobj) (princ "\n*******END OF ITEM #")(princ i)(princ "\n\n") ) (princ "no selection found!") ) (princ) ) Ready to go! Command: TESTno selection found! hmmm.. in console? same as integrated in a lisp.. _$ (setq zzz (ssget "x" '((0 . "drawingview"))))nil but in command line(using the "if"), it make Autocad sing... Command: (if (setq zzz (ssget "x" '((0 . "drawingview")))) (_> (repeat (setq i (sslength zzz)) ((_> (setq e (ssname zzz (setq i (1- i))) (((_> VLobj (vlax-ename->vla-object e) (((_> ) ((_> (princ "item #")(princ i)(princ ": Result of dumpallproperties: \n") (dumpallproperties e) ((_> (princ "\n\nitem #")(princ i)(princ ": Result of vlax-dump-object: \n")(vlax-dump-object vlobj) ((_> (princ "\n*******END OF ITEM #")(princ i)(princ "\n\n") ((_> ) (_> (princ "no selection found!") (_> ) item #1: Result of dumpallproperties: Begin dumping object (class: AcDbViewBorder) Annotative (type: bool) (LocalName: Annotative) = Failed to get value AnnotativeScale (type: AcString) (RO) (LocalName: Annotative scale) = Failed to get value BlockId (type: AcDbObjectId) (RO) = 7ffffb52670 CastShadows (type: bool) = 1 ClassName (type: AcString) (RO) = CollisionType (type: AcDb::CollisionType) (RO) = 1 Color (type: AcCmColor) (LocalName: Color) = BYLAYER CustomScale (type: double) (RO) (LocalName: Custom scale) = 4.000000 DesignView (type: AcString) (RO) (LocalName: Design view) = Failed to get value DetailBoundaryShape (type: AcDbViewProp::DetailBoundaryType) (LocalName: Boundary type) = Failed to get value DetailIdentifier (type: AcString) (LocalName: Detail identifier) = Failed to get value EndIdentifier (type: AcString) (RO) (LocalName: End identifier) = Failed to get value ExtensionDictionary (type: AcDbObjectId) (RO) = 0 FamilyMember (type: AcString) (RO) (LocalName: Family member) = Failed to get value Handle (type: AcDbHandle) (RO) = 7eb85 HasFields (type: bool) (RO) = 0 HasSaveVersionOverride (type: bool) = 0 Height (type: double) (RO) (LocalName: Height) = 2.913089 HiddenLineCalculation (type: aciv::ViewEnums::ERefAndNonRefTreatment) (RO) (LocalName: Hidden line calculation) = Failed to get value Hyperlinks (type: AcDbHyperlink*) InheritSectioncut (type: AcDbViewFacet::YesNoType) (RO) (LocalName: Inherit section cut) = Failed to get value InsertionPointX (type: double) (LocalName: Insertion point X) = 10.278607 InsertionPointY (type: double) (LocalName: Insertion point Y) = 8.392718 InsertionPointZ (type: double) (RO) (LocalName: Insertion point Z) = 0.000000 InterferenceEdges (type: AcDbViewFacet::OnOffType) (RO) (LocalName: Interference edges) = Failed to get value IsA (type: AcRxClass*) (RO) = AcDbViewBorder IsAProxy (type: bool) (RO) = 0 IsCancelling (type: bool) (RO) = 0 IsEraseStatusToggled (type: bool) (RO) = 0 IsErased (type: bool) (RO) = 0 IsModified (type: bool) (RO) = 0 IsModifiedGraphics (type: bool) (RO) = 0 IsModifiedXData (type: bool) (RO) = 0 IsNewObject (type: bool) (RO) = 0 IsNotifyEnabled (type: bool) (RO) = 0 IsNotifying (type: bool) (RO) = 0 IsObjectIdsInFlux (type: bool) (RO) = 0 IsPersistent (type: bool) (RO) = 1 IsPlanar (type: bool) (RO) = 0 IsReadEnabled (type: bool) (RO) = 1 IsReallyClosing (type: bool) (RO) = 1 IsTransactionResident (type: bool) (RO) = 0 IsUndoing (type: bool) (RO) = 0 IsWriteEnabled (type: bool) (RO) = 0 Justification (type: aciv::ViewEnums::EViewJustification) (RO) (LocalName: Justification) = 1 LabelPosition (type: AcDbViewProp::LabelPositionType) (LocalName: Label position) = Failed to get value LayerId (type: AcDbObjectId) (LocalName: Layer) = 7ffffbb8f60 LevelOfDetailRepresentation (type: AcString) (RO) (LocalName: Level of detail representation) = Failed to get value LineWeight (type: AcDb::LineWeight) (LocalName: Lineweight) = Failed to get value Linetype (type: AcDbViewProp::LineType) (RO) (LocalName: Line style) = Failed to get value LinetypeId (type: AcDbObjectId) (LocalName: Linetype) = Failed to get value LinetypeScale (type: double) (LocalName: Linetype scale) = Failed to get value LocalizedName (type: AcString) (RO) = Drawing View MaterialId (type: AcDbObjectId) (LocalName: Material) = Failed to get value MergeStyle (type: AcDb::DuplicateRecordCloning) (RO) = 1 ModelEdge (type: AcDbDetailViewStyle::ModelEdge) (LocalName: Model edge) = Failed to get value Name (type: AcString) (RO) (LocalName: Name) = Failed to get value ObjectId (type: AcDbObjectId) (RO) = 7ffffb549d0 OwnerId (type: AcDbObjectId) (RO) = 7ffffb52670 Path (type: AcString) (RO) (LocalName: Path) = Failed to get value PlotStyleName (type: AcString) (LocalName: Plot style) = ByLayer PositionalRepresentation (type: AcString) (RO) (LocalName: Positional representation) = Failed to get value PreparationName (type: AcString) (RO) (LocalName: Preparation name) = Failed to get value PresentationTrails (type: AcDbViewFacet::OnOffType) (RO) (LocalName: Presentation trails) = Failed to get value PresentationView (type: AcString) (RO) (LocalName: Presentation view) = Failed to get value ProjectionAngle (type: AcDbViewRepStandard::ProjectionType) (RO) (LocalName: Projection angle) = 1 ReceiveShadows (type: bool) = 1 Rotation (type: double) (LocalName: Rotation) = 0.000000 SectionDepth (type: AcDbViewProp::SectionDepthType) (LocalName: Depth) = Failed to get value SectionDistance (type: double) (LocalName: Distance) = Failed to get value SectionProjection (type: AcDbViewProp::SectionProjectionType) (RO) (LocalName: Projection) = Failed to get value ShadeResolution (type: AcDbViewRepStandard::DpiResolutionType) (RO) (LocalName: Shade resolution) = 100 ShadowDisplay (type: AcDb::ShadowFlags) (LocalName: Shadow Display) = Failed to get value SheetMetalBendExtents (type: AcDbViewFacet::OnOffType) (RO) (LocalName: Sheet metal bend extents) = Failed to get value SheetMetalState (type: AcDbViewProp::SheetMetalType) (RO) (LocalName: Sheet metal state) = Failed to get value ShowHatching (type: AcDbViewFacet::YesNoType) (LocalName: Show hatching) = Failed to get value ShowViewLabel (type: AcDbViewFacet::YesNoType) (LocalName: Show view label) = Failed to get value Source (type: AcDbViewRep::SourceType) (RO) (LocalName: Source) = 3 StandardScale (type: ScaleValue) (LocalName: Standard scale) = 2 StandardScaleViewLabel (type: AcString) (RO) = 4:1 StartIdentifier (type: AcString) (LocalName: Start identifier) = Failed to get value TangentEdges (type: AcDbViewFacet::OnOffType) (RO) (LocalName: Tangent edges) = 0 TangentEdgesForeshortened (type: AcDbViewFacet::OnOffType) (RO) (LocalName: Tangent edges foreshortened) = 0 ThreadFeatures (type: AcDbViewFacet::OnOffType) (RO) (LocalName: Thread features) = Failed to get value Transparency (type: AcCmTransparency) (LocalName: Transparency) = 0 ViewAignment (type: AcDbViewProp::AlignmentType) (RO) (LocalName: View alignment) = Failed to get value ViewStyle (type: AcDbViewProp::ViewStyleType) (RO) (LocalName: Hidden lines) = 2 ViewType (type: AcDbViewProp::ViewType) (RO) (LocalName: View type) = 0 Visible (type: AcDb::Visibility) = 0 WeldmentState (type: AcDbViewProp::WeldmentType) (RO) (LocalName: Weldment state) = Failed to get value Width (type: double) (RO) (LocalName: Width) = 4.619484 End object dump item #1: Result of vlax-dump-object: ; IAcadViewBorderWrapper: nil ; Property values: ; Application (RO) = #<VLA-OBJECT IAcadApplication 0000000140469110> ; Document (RO) = #<VLA-OBJECT IAcadDocument 00000000289aaa78> ; EntityTransparency = "ByLayer" ; Handle (RO) = "7EB85" ; HasExtensionDictionary (RO) = 0 ; Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 00000000391ac568> ; Layer = "DIM" ; Linetype = "ACAD_VIEWBORDER_LINETYPE" ; LinetypeScale = 0.25 ; Lineweight = -1 ; Material = "ByLayer" ; ObjectID (RO) = 43 ; ObjectName (RO) = "AcDbViewBorder" ; OwnerID (RO) = 45 ; PlotStyleName = "ByLayer" ; TrueColor = #<VLA-OBJECT IAcadAcCmColor 00000000391a91a0> ; Visible = -1 *******END OF ITEM #1 item #0: Result of dumpallproperties: Begin dumping object (class: AcDbViewBorder) Annotative (type: bool) (LocalName: Annotative) = Failed to get value AnnotativeScale (type: AcString) (RO) (LocalName: Annotative scale) = Failed to get value BlockId (type: AcDbObjectId) (RO) = 7ffffb52670 CastShadows (type: bool) = 1 ClassName (type: AcString) (RO) = CollisionType (type: AcDb::CollisionType) (RO) = 1 Color (type: AcCmColor) (LocalName: Color) = BYLAYER CustomScale (type: double) (RO) (LocalName: Custom scale) = 4.000000 DesignView (type: AcString) (RO) (LocalName: Design view) = Failed to get value DetailBoundaryShape (type: AcDbViewProp::DetailBoundaryType) (LocalName: Boundary type) = Failed to get value DetailIdentifier (type: AcString) (LocalName: Detail identifier) = Failed to get value EndIdentifier (type: AcString) (RO) (LocalName: End identifier) = Failed to get value ExtensionDictionary (type: AcDbObjectId) (RO) = 0 FamilyMember (type: AcString) (RO) (LocalName: Family member) = Failed to get value Handle (type: AcDbHandle) (RO) = 7ebd8 HasFields (type: bool) (RO) = 0 HasSaveVersionOverride (type: bool) = 0 Height (type: double) (RO) (LocalName: Height) = 0.844753 HiddenLineCalculation (type: aciv::ViewEnums::ERefAndNonRefTreatment) (RO) (LocalName: Hidden line calculation) = Failed to get value Hyperlinks (type: AcDbHyperlink*) InheritSectioncut (type: AcDbViewFacet::YesNoType) (RO) (LocalName: Inherit section cut) = Failed to get value InsertionPointX (type: double) (LocalName: Insertion point X) = 10.278607 InsertionPointY (type: double) (LocalName: Insertion point Y) = 11.425951 InsertionPointZ (type: double) (RO) (LocalName: Insertion point Z) = 0.000000 InterferenceEdges (type: AcDbViewFacet::OnOffType) (RO) (LocalName: Interference edges) = Failed to get value IsA (type: AcRxClass*) (RO) = AcDbViewBorder IsAProxy (type: bool) (RO) = 0 IsCancelling (type: bool) (RO) = 0 IsEraseStatusToggled (type: bool) (RO) = 0 IsErased (type: bool) (RO) = 0 IsModified (type: bool) (RO) = 0 IsModifiedGraphics (type: bool) (RO) = 0 IsModifiedXData (type: bool) (RO) = 0 IsNewObject (type: bool) (RO) = 0 IsNotifyEnabled (type: bool) (RO) = 0 IsNotifying (type: bool) (RO) = 0 IsObjectIdsInFlux (type: bool) (RO) = 0 IsPersistent (type: bool) (RO) = 1 IsPlanar (type: bool) (RO) = 0 IsReadEnabled (type: bool) (RO) = 1 IsReallyClosing (type: bool) (RO) = 1 IsTransactionResident (type: bool) (RO) = 0 IsUndoing (type: bool) (RO) = 0 IsWriteEnabled (type: bool) (RO) = 0 Justification (type: aciv::ViewEnums::EViewJustification) (RO) (LocalName: Justification) = 1 LabelPosition (type: AcDbViewProp::LabelPositionType) (LocalName: Label position) = Failed to get value LayerId (type: AcDbObjectId) (LocalName: Layer) = 7ffffbb8f60 LevelOfDetailRepresentation (type: AcString) (RO) (LocalName: Level of detail representation) = Failed to get value LineWeight (type: AcDb::LineWeight) (LocalName: Lineweight) = Failed to get value Linetype (type: AcDbViewProp::LineType) (RO) (LocalName: Line style) = Failed to get value LinetypeId (type: AcDbObjectId) (LocalName: Linetype) = Failed to get value LinetypeScale (type: double) (LocalName: Linetype scale) = Failed to get value LocalizedName (type: AcString) (RO) = Drawing View MaterialId (type: AcDbObjectId) (LocalName: Material) = Failed to get value MergeStyle (type: AcDb::DuplicateRecordCloning) (RO) = 1 ModelEdge (type: AcDbDetailViewStyle::ModelEdge) (LocalName: Model edge) = Failed to get value Name (type: AcString) (RO) (LocalName: Name) = Failed to get value ObjectId (type: AcDbObjectId) (RO) = 7ffffb54f00 OwnerId (type: AcDbObjectId) (RO) = 7ffffb52670 Path (type: AcString) (RO) (LocalName: Path) = Failed to get value PlotStyleName (type: AcString) (LocalName: Plot style) = ByLayer PositionalRepresentation (type: AcString) (RO) (LocalName: Positional representation) = Failed to get value PreparationName (type: AcString) (RO) (LocalName: Preparation name) = Failed to get value PresentationTrails (type: AcDbViewFacet::OnOffType) (RO) (LocalName: Presentation trails) = Failed to get value PresentationView (type: AcString) (RO) (LocalName: Presentation view) = Failed to get value ProjectionAngle (type: AcDbViewRepStandard::ProjectionType) (RO) (LocalName: Projection angle) = 1 ReceiveShadows (type: bool) = 1 Rotation (type: double) (LocalName: Rotation) = 0.000000 SectionDepth (type: AcDbViewProp::SectionDepthType) (LocalName: Depth) = Failed to get value SectionDistance (type: double) (LocalName: Distance) = Failed to get value SectionProjection (type: AcDbViewProp::SectionProjectionType) (RO) (LocalName: Projection) = Failed to get value ShadeResolution (type: AcDbViewRepStandard::DpiResolutionType) (RO) (LocalName: Shade resolution) = 100 ShadowDisplay (type: AcDb::ShadowFlags) (LocalName: Shadow Display) = Failed to get value SheetMetalBendExtents (type: AcDbViewFacet::OnOffType) (RO) (LocalName: Sheet metal bend extents) = Failed to get value SheetMetalState (type: AcDbViewProp::SheetMetalType) (RO) (LocalName: Sheet metal state) = Failed to get value ShowHatching (type: AcDbViewFacet::YesNoType) (LocalName: Show hatching) = Failed to get value ShowViewLabel (type: AcDbViewFacet::YesNoType) (LocalName: Show view label) = Failed to get value Source (type: AcDbViewRep::SourceType) (RO) (LocalName: Source) = 3 StandardScale (type: ScaleValue) (LocalName: Standard scale) = 0 StandardScaleViewLabel (type: AcString) (RO) = 4:1 StartIdentifier (type: AcString) (LocalName: Start identifier) = Failed to get value TangentEdges (type: AcDbViewFacet::OnOffType) (RO) (LocalName: Tangent edges) = 0 TangentEdgesForeshortened (type: AcDbViewFacet::OnOffType) (RO) (LocalName: Tangent edges foreshortened) = 0 ThreadFeatures (type: AcDbViewFacet::OnOffType) (RO) (LocalName: Thread features) = Failed to get value Transparency (type: AcCmTransparency) (LocalName: Transparency) = 0 ViewAignment (type: AcDbViewProp::AlignmentType) (LocalName: View alignment) = 0 ViewStyle (type: AcDbViewProp::ViewStyleType) (RO) (LocalName: Hidden lines) = 0 ViewType (type: AcDbViewProp::ViewType) (RO) (LocalName: View type) = 1 Visible (type: AcDb::Visibility) = 0 WeldmentState (type: AcDbViewProp::WeldmentType) (RO) (LocalName: Weldment state) = Failed to get value Width (type: double) (RO) (LocalName: Width) = 4.619484 End object dump item #0: Result of vlax-dump-object: ; IAcadViewBorderWrapper: nil ; Property values: ; Application (RO) = #<VLA-OBJECT IAcadApplication 0000000140469110> ; Document (RO) = #<VLA-OBJECT IAcadDocument 00000000289aaa78> ; EntityTransparency = "ByLayer" ; Handle (RO) = "7EBD8" ; HasExtensionDictionary (RO) = 0 ; Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 00000000396ec468> ; Layer = "DIM" ; Linetype = "ACAD_VIEWBORDER_LINETYPE" ; LinetypeScale = 0.25 ; Lineweight = -1 ; Material = "ByLayer" ; ObjectID (RO) = 46 ; ObjectName (RO) = "AcDbViewBorder" ; OwnerID (RO) = 45 ; PlotStyleName = "ByLayer" ; TrueColor = #<VLA-OBJECT IAcadAcCmColor 00000000396ed960> ; Visible = -1 *******END OF ITEM #0 "\n\n" Why wont that work added into a lisp command? Any comments, ideas, suggestions ... alternate way of... anything to shed light on me are welcome Cheers, Jef! Quote
Tharwat Posted February 5, 2015 Posted February 5, 2015 I don't have that object name drawingview to test the program , but try to get used to localize variables in every program you may write to avoid the intervention between programs if variables are matched in any case . One more thing is to replace the mode string of the ssget function from "x" to "_X" . Quote
Jef! Posted February 5, 2015 Author Posted February 5, 2015 Hi Tharwat... To have a drawing view, you must have at least a 1 solid3d model or inventor files.(*.iam, *.ipt, *.ipn) you can create a box in model, then in paperspace type "viewbase", then make 1 with few clicks. For the variables, I do systematically localize every variable. Ive unlocalized them only for debug purposes, and when i do I make sure to check them all first Command: !zzznil Command: !i nil Command: !e nil Command: !VLobj nil I really could use a few hours class on how to use the full power of the vlide and debuging/var monitoring without having to unlocalize them, as it is a pita when trying to debug multiple routines working together. Thanks for the input on "_X" instead of "x", i never noticed that one. I've tryed to make the change, the result remains the same. Command: (defun C:test ( / zzz i e VLobj)(_> (if (setq zzz (ssget "_X" '((0 . "drawingview")))) ((_> (repeat (setq i (sslength zzz)) (((_> (setq e (ssname zzz (setq i (1- i))) ((((_> VLobj (vlax-ename->vla-object e) ((((_> ) (((_> (princ "item #")(princ i)(princ ": Result of dumpallproperties: \n") (dumpallproperties e) (((_> (princ "\n\nitem #")(princ i)(princ ": Result of vlax-dump-object: \n")(vlax-dump-object vlobj) (((_> (princ "\n*******END OF ITEM #")(princ i)(princ "\n\n") (((_> ) ((_> (princ "no selection found!") ((_> ) (_> (princ) (_> ) C:TEST Command: TEST no selection found! ...and again with only the "if" portion (which is everything except the final (princ) Cad sings like a bird and it works like a charm. Quote
Lee Mac Posted February 5, 2015 Posted February 5, 2015 I've also observed this behaviour when working with DRAWINGVIEW objects, as I have previously tried to automate a process of centering drawing views in a sheet of a fixed size. I found that the views may be selected when expressions are evaluated at the command-line, but not when evaluated from within an AutoLISP command; I have also found this behaviour to be apparent when issuing a 'manual' ssget selection (as opposed to using the "X" mode string). It would seem that a restriction has been imposed on manipulating drawing views using AutoLISP, and I'm not sure there is any way around this. Lee Quote
Jef! Posted February 5, 2015 Author Posted February 5, 2015 Hi Lee, thanks for poping in. I'm not sure I understand what you are reffering to when you talk about a "manual" ssget.. would there be another way of not "x" ssget-ing them? If YOU tried to manipulate drawing views and have not found any way around the restriction, I don't think I have a much chope of achieving anything more than you. I'm sure you tried many (if not all approaches) lisp, vlisp, Active-X, vodoo dolls and spell casting. My feeling on why they sometimes seems to put restrictions such as these is that they are affraid of killing their own market on some of their other softwares. Anyway.. if i find a way ill let you know, likewise if you find something new, let us know! thanks Quote
Lee Mac Posted February 5, 2015 Posted February 5, 2015 I'm not sure I understand what you are reffering to when you talk about a "manual" ssget.. would there be another way of not "x" ssget-ing them? I mean a non-automated selection, observe the following command-line output when attempting to select the same drawing view object: Command: (ssget) Select objects: Specify opposite corner: 1 found Select objects: <Selection set: 53> Command: (defun c:test nil (ssget)) C:TEST Command: test Select objects: Specify opposite corner: 1 found 1 was filtered out Select objects: nil If YOU tried to manipulate drawing views and have not found any way around the restriction, I don't think I have a much chope of achieving anything more than you. I'm sure you tried many (if not all approaches) lisp, vlisp, Active-X, vodoo dolls and spell casting. Haha! I did try a good few different methods, but certainly feel free to experiment yourself! My feeling on why they sometimes seems to put restrictions such as these is that they are affraid of killing their own market on some of their other softwares. In this case I don't think this is an intentional restriction implemented by Autodesk, but rather a subtle consequence of objects such as drawing views being introduced long after development of the AutoLISP API has ceased and therefore such objects don't play well. /just a guess. Lee Quote
Jef! Posted February 5, 2015 Author Posted February 5, 2015 Leeeeeeee! Tell me what you think about that (defun test2 ( *SEL* / i e VLobj) (repeat (setq i (sslength *SEL*)) (setq e (ssname *SEL* (setq i (1- i))) VLobj (vlax-ename->vla-object e) ) (princ "item #")(princ i)(princ ": Result of dumpallproperties: \n") (dumpallproperties e) (princ "\n\nitem #")(princ i)(princ ": Result of vlax-dump-object: \n")(vlax-dump-object vlobj) (princ "\n*******END OF ITEM #")(princ i)(princ "\n\n") ) (if zzz (setq zzz nil)) (princ) ) Then try adding a custom button in a toolbar, and as a macro add that ^C^C(if (setq zzz (ssget "_X" '((0 . "drawingview"))))(TEST2 ZZZ)(princ "no selection found!"))(princ) To dump properties, it works! Now what I have to figure out is if properties can be modified in the same manner... I didnt have much luck so far to retrieve them, because the props I need are only available with lisp (dumpallproperties) and not with (vlax-dump-object). I tried to retrieve the scale but didnt manage.. Here'S what i tried to add in my repeat (setq scale (getpropertyVALUE e 'CustomScale)) but it did not return anything... I'm not even sure I'm doing the correct thing, ill have to make some research on that, unless you shed some light on how to retrieve/modify them. i guess that only properties seen with (vlax-dump-object) can be retrieved/modified with (vla-get-property) and (vla-put-property) ?? For now I need to retrieve all the drawing views scales, and supress some. I'll sleep on that for tonight, ill dig further in tomorrow. In the meantime, if you investigate on that, i'll be glad to read what your discoveries were... I hope my findings can be usefull... 1 Quote
oberkarl Posted August 1, 2023 Posted August 1, 2023 Any chance you were able to figure out a way around this bug? Quote
oberkarl Posted August 2, 2023 Posted August 2, 2023 I believe that I have found a work around solution, but a solution nonetheless. It utilizes calling a script mid program which in turn calls the original lisp back. A few global variables manage the passing of data between the two. Due to this use of global variables proceed with great care. I have attached a program I wrote that automatically fixes dims to Viewports and Viewbase for you. See structure for technique to select and manipulate Drawing Views. (Make sure to update the Filepath on Line 104 for where you'll save the script file to) Credit to Lee for several subfunctions that help with writing the script within the lisp program. FIXDIMS.lsp Quote
