Hello all
I decided to write my own code to put the selected middle centred text at it's insertion point at the middle centre of two points..
It works great using entsel (semi-coloned off), but errors with ssget as it says it would on Lee Mac's tutorial on ssget
I'd be happy with entsel, but I'd prefer a filter to only select *text
(0 . "TEXT,MTEXT")
My attempt is:
(defun c:test ( / ang ent insp midp obj p1 p2)
(setvar "osmode" 51);; osnap to endpoint, midpoint, quadrant & intersection
  (setq obj (ssget "\nSelect text or mtext: " '("_+.:E:S" ((0 . "TEXT,MTEXT")))))
  ;(setq obj (entsel "\nSelect text or mtext: "))
  (command "justifytext" obj "" "MC")
(setq ent (cdr(assoc 0 (entget (car obj)))))
  ;(princ (strcat "The type of entity is " ent)); Testing purposes only
   (setq p1 (getpoint "\nPick Point 1: "))
   (setq p2 (getpoint "\nPick Point 2: "))
 (setq ang (angle p1 p2))
 (setq midp (polar p1 ang (* (distance p1 p2) 0.5)))
(cond
       ((= ent "TEXT")
 ;(princ "\nThis is Text at: "); Testing purposes only
 ;(princ insp); Prints coordinates of mtext entity - Testing purposes only
 	 (setq insp (cdr (assoc 11 (entget (car obj)))));; coordinates of text entity
 (command "_move" obj "" "_none" insp "_none" midp)
       ((= ent "MTEXT")
 ;(princ "\nThis is MText at"); Testing purposes only
 (setq insp (cdr (assoc 10 (entget (car obj)))));; coordinates of mtext entity
   )  (setvar "osmode" 0); turns off all osnaps
Forgive all the semi colons, I'm still testing it
P.S. Please don't re-write, please point out where I'm going wrong
Edited by Happy Hobbit
typo
  • Replies 26
  • Lee Mac
    10
  • Happy Hobbit
    8
  • ILoveMadoka
    6
  • yathishkumar
    2
Posted Images
After a quick glance,
Should be:
(setq obj (ssget "_+.:E:S" '((0 . "TEXT,MTEXT"))))
You cannot issue a user prompt using the standard ssget function.
Thank you for that Lee & thank you for not taking the p
Unfortunately without the entget it's now crashing on:
Yes, you will need to retrieve the entity name from the selection set acquired by ssget using the ssname function - since there is only one object selected, this entity will reside at index 0.
using this for mtext?
(setq insp (cdr (assoc 10 (entget (ssname obj 0)))))
And this for text
	(setq insp (cdr (assoc 11 (entget (ssname obj 0)))))
I actually think it's sorted thanks to you Lee & your website
Ta much
Just in case anyone else can use my humble finished code:
(defun c:Move2MC ( / ang ent insp mc obj oso p1 p2 )
(setq oso (getvar "osmode"))
 (princ "\nSelect text or mtext: ")
 (if
(setq ent (cdr (assoc 0 (entget (ssname obj 0)))))
 (setq mc (polar p1 ang (* (distance p1 p2) 0.5)))
(cond
       ((= ent "TEXT")
       ((= ent "MTEXT")
   (princ "\n** Missed, Try again **")
 (command "_move" obj "" "_none" insp "_none" mc)
 (setvar "osmode" oso); returns to previous osmode setting
Simplified it a little
