alcatel Posted January 27, 2015 Share Posted January 27, 2015 Does anyone know how to achieve this? I have a series of blocks with attributes in Autocad. Attribute is a number (from 1 to 500). Each of the blocks represents a single machine with serial number 1-500 on it. When I place a new block of machine (I do it by copy/paste from the nearby block) I just change the attribute value manually. Now, as a separate file I have excel sheet with two columns: COLUMN A -> serial number of machines (1-500) COLUMN B -> type of machine (e.g. TYPE-1, TYPE-2, TYPE-3...), around 8 types in total Is it possible to make a block with two values in it (attributes) and when a value of machine serial number in position 1 is changed it will look the excel file and return the machine type in position 2. Something like VLOOKUP excel formula, but in AUTOCAD. For example if EXCEL is: COLUMN A / COLUMN B 250 / TYPE-3 251 / TYPE-5 Than the change in AutoCAD attributes in position 1 and 2 is like this: ATT-1: 250 ATT-2: TYPE-3 if I manually change ATT-1 to value 251, then: ATT-1: 251 ATT-2: TYPE-3 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 28, 2015 Share Posted January 28, 2015 I would look at some of the incrementing lisps so when add block it adds next number automatically. They work by looking up your block and retrieving the highest value. have a Look at www.Lee-mac.com auto numbering suite. Here is an example of finding last number. (setq ss1 (ssget "x" '((2 . "setout_point")))) (setq pno 0) (setq n (sslength ss1)) (setq index 0) (repeat n (setq en (ssname ss1 index)) (setq index (+ index 1)) (setq en1 (entnext en)) (setq el1 (entget en1)) (setq att (atoi (cdr (assoc 1 el1)))) (if (> att pno) (setq pno att)) );repeat (setq pno (+ pno 1)) Quote Link to comment Share on other sites More sharing options...
