Dear Sir,
I came across this lisp routines that would let you select each line in a drawing
and it would create a line and bearing table. I was able to make small
modifications to it, but I could not figure out how to make it use
the current text style.
Please see link below - - -
Any assistance would be much appreciated,
Thank you
http://www.cadtutor.net/forum/showthread.php?49329-Generate-Bearings-amp-Distances-into-table
This is a bit long but I think what you want is at bottom.
; example of creating a table style
(vl-load-com)
(defun c:CreateTableStyle()
   ;; Get the AutoCAD application and current document
   (setq acad (vlax-get-acad-object))
   (setq doc (vla-get-ActiveDocument acad))
   ;; Get the Dictionaries collection and the TableStyle dictionary
   (setq dicts (vla-get-Dictionaries doc))
   (setq dictObj (vla-Item dicts "acad_tablestyle"))
   ;; Create a custom table style
   (setq key "MyTableStyle"
         class "AcDbTableStyle")
   (setq custObj (vla-AddObject dictObj key class))
   ;; Set the name and description for the style
   (vla-put-Name custObj "MyTableStyle")
   (vla-put-Description custObj "This is my custom table style")
   ;; Sets the bit flag value for the style
   (vla-put-BitFlags custObj 1)
   ;; Sets the direction of the table, top to bottom or bottom to top
   (vla-put-FlowDirection custObj acTableTopToBottom)
   ;; Sets the supression of the table header
   (vla-put-HeaderSuppressed custObj :vlax-false)
   ;; Sets the horizontal margin for the table cells
   (vla-put-HorzCellMargin custObj 0.22)
   ;; Sets the supression of the table title
   (vla-put-TitleSuppressed custObj :vlax-false)
   ;; Sets the vertical margin for the table cells
   (vla-put-VertCellMargin custObj 0.22)
   ;; Set the alignment for the Data, Header, and Title rows
   (vla-SetAlignment custObj (+ acDataRow acTitleRow) acMiddleLeft)
   (vla-SetAlignment custObj acHeaderRow acMiddleCenter)
   ;; Set the background color for the Header and Title rows
   (setq colObj (vlax-create-object "AutoCAD.AcCmColor.19"))
   (vla-SetRGB colObj 98 136 213)
   (vla-SetBackgroundColor custObj (+ acHeaderRow acTitleRow) colObj)
   ;; Clear the background color for the Data rows
   (vla-SetBackgroundColorNone custObj acDataRow :vlax-true)
   ;; Set the bottom grid color for the Title row
   (vla-SetRGB colObj 0 0 255)
   (vla-SetGridColor custObj acHorzBottom acTitleRow colObj)
   ;; Set the bottom grid lineweight for the Title row
   (vla-SetGridLineWeight tableStyle acHorzBottom acTitleRow acLnWt025)
   ;; Set the inside grid lines visible for the data and header rows
   (vla-SetGridVisibility custObj acHorzInside  (+ acDataRow acHeaderRow) :vlax-true)
   ;; Set the text height for the Title, Header and Data rows
   (vla-SetTextHeight custObj acTitleRow 1.5)
   (vla-SetTextHeight custObj (+ acDataRow acHeaderRow) 1.0)
   ;; Set the text height and style for the Title row
   (vla-SetTextStyle custObj (+ acDataRow acHeaderRow acTitleRow) "Standard")
   ;; Release the color object
   (vlax-release-object colObj)
Earlier I posted a thread about a problem with a lisp routine that
I found that needed a little tweeking. It seems that there was
confusion about which routine I was referring to so I am attempting
to resend the request with the program attached.
The routine is a Line Bearing Table. I would like for it to use the
current drawing's Text Style. Again any assistance would greatly
appreciated. Please see attached.
BEARING TBL.lsp
Needed to "attach" a file and did not see where to do that with "Quick Reply"
Thanks
