Overlap of horizontal label in profile view.
Any tips/tricks to deal with this type of overlap?
Thanks
  • 3 weeks later...
The easiest way I have found is to simply make your Profile a little longer.
Under Profile view properties - Select "user specified range" then add distance to the End number.
This has always bothered me as well... You *should* be able to Ctrl+Click (select) the undesired label, and then hit key, just like you can on an individual Alignment, or [Profile View] Band label. Grrr
If enough of us complain it should be fixed by R-2030
then again maybe not........................
