camril Posted December 15, 2008 Posted December 15, 2008 I need to locate 4 little circles with array command. The problem: I don't know how to do it, that circles would be in the big circle sides (like in picture 1). I know that I need to use Polar array. But something in the table or in the drawing is wrong, because when I press OK, I get messy circles screen. Quote
eldon Posted December 16, 2008 Posted December 16, 2008 You draw one item in the correct place, then use polar array to copy that around a circle. So in your screen shot, you have selected four objects instead of the one needed. Quote
dbroada Posted December 16, 2008 Posted December 16, 2008 camril, a word of advice. Don't edit your posts after you get an answer. It won't show up on the most recent posts list and can easilly be missed. Quote
camril Posted December 16, 2008 Author Posted December 16, 2008 You draw one item in the correct place, then use polar array to copy that around a circle. So in your screen shot, you have selected four objects instead of the one needed. Thank you so much for your answer. Quote
mugshot Posted December 18, 2008 Posted December 18, 2008 ...sometimes, people can be a h_ _ _ _ _! Quote
